sim1987 Posted February 12, 2011 Share Posted February 12, 2011 hi all i have been trying to fix my 94 sz manual n/a and cant seem to find the source of the problem. it all started after i got the car back from geting a set of exhaust valves and head gasket fited due to the exhaust valves being bent, shortly after it started steaming out of the expansion tank.i have had a look on a few postes on the forum and found a few things to check i have since: 1.replaced the thermostat. 2.replaced the rad hoses and checked rad. 3.checked the water pump it is ok. 4.fitted new rad cap standard from toyota. 5.heater matrix fine blowing hot air and no damp footwells. even after all this it is still steaming from the expansion i thought maby there is a slight leak in the head gasket as it takes some time to overheat maby 30min . i have runout of ideas please any info appreciated not giving up cant bear to loose the sup.[sAD][/sAD] Quote Link to comment Share on other sites More sharing options...
nevins Posted February 12, 2011 Share Posted February 12, 2011 Get a sniff test done on the cooling system, this will give an indication if you have a HG problem Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 i am trying to get it booked in to get the sniff test i am praying that it aint the HG its a brand new HG that is on it running out of funds fast to. Quote Link to comment Share on other sites More sharing options...
nevins Posted February 12, 2011 Share Posted February 12, 2011 Any idea how the valves bent, if it was due to a foreign object then it might have damaged something else, or it could be down to human error Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 the mechanic that did the valves for me was a mate of my dads i have since found out he is a bit of a cowboy so i am going to get all the work he did checked as for the valves it was human error i thinkwas out one day giving it a bit o stick and may have over reved it slightly. Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 12, 2011 Share Posted February 12, 2011 Any idea how the valves bent, if it was due to a foreign object then it might have damaged something else, or it could be down to human error As that there welsh man just said! (although not sure how human error could even manage that!) How did you manage to bend valves! I can tell you the problem, it's a manual... they suffer from head gaskets. Best option is to sell me your gear box, diff and shafts and put it down to a dodgy motor mate! hahaha If your not willing to do that, then i'd have a go at trying to bleed all the air out the cooling system mate, that sounds like your problem. Are you getting hot air out the heater vents? Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 As that there welsh man just said! How did you manage to bend valves! I can tell you the problem, it's a manual... they suffer from head gaskets. Best option is to sell me your gear box, diff and shafts and put it down to a dodgy motor mate! hahaha If your not willing to do that, then i'd have a go at trying to bleed all the air out the cooling system mate, that sounds like your problem. Are you getting hot air out the heater vents? hot air coming out of the heater vents no problems there and no damp paches in the footwells dont think heater matrix is the prob as for air i have had the car jacked about 3feet of the ground at the front running with the rad cap of and a/c on full still steaming after 20-30min if i cant fix it think il just put the 2jzgte in it instead. Quote Link to comment Share on other sites More sharing options...
nevins Posted February 12, 2011 Share Posted February 12, 2011 As that there welsh man just said! (although not sure how human error could even manage that!) How did you manage to bend valves! I can tell you the problem, it's a manual... they suffer from head gaskets. Best option is to sell me your gear box, diff and shafts and put it down to a dodgy motor mate! hahaha If your not willing to do that, then i'd have a go at trying to bleed all the air out the cooling system mate, that sounds like your problem. Are you getting hot air out the heater vents? On the human error side of things I meant on rebuild. Like you said not bleeding the system fully. Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 On the human error side of things I meant on rebuild. Like you said not bleeding the system fully. sorry mate got wrong idea as i mentioned the mechanics skill has come in to question latly it is my intention to get all the dodgy f***ers work checked by a good guyi know has done work on these sort of cars before. Quote Link to comment Share on other sites More sharing options...
nevins Posted February 12, 2011 Share Posted February 12, 2011 I know the feeling mate, me and craig are repairing screw ups by mechanics all the time. Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 I know the feeling mate, me and craig are repairing screw ups by mechanics all the time. i knpw it all to well. i am a mechanic for bp in grangemouth so i know a bit abought the cars mechanics but the problem is i just havent got the time of the faciliteis to do the work myself if only i could win the euro millions lol Quote Link to comment Share on other sites More sharing options...
nevins Posted February 12, 2011 Share Posted February 12, 2011 If the mechanics as dodgy as you think, not wanting to concern you but we had one fool down here re using the HG. Needless to say he is out of business now. Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 If the mechanics as dodgy as you think, not wanting to concern you but we had one fool down here re using the HG. Needless to say he is out of business now. i would have had him burned at the stake how much more stupid can you get honestly. Quote Link to comment Share on other sites More sharing options...
nevins Posted February 12, 2011 Share Posted February 12, 2011 Was the type of person who reused brake fluid, and engine coolant and scavenge parts of customers cars to repair others, done it to a mates car so we dealt with it. Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 sounds kind of like one of the guys i work with this guy takes compressor oill from the work for his car because hes to cheap to buy it the dodgy f**ks on 40k a year lol Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 just a thought but are the HGs for the turbo and the N/A the same. because he told me he could only get a gasket for the gte. Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 12, 2011 Share Posted February 12, 2011 just a thought but are the HGs for the turbo and the N/A the same. because he told me he could only get a gasket for the gte. HAHAHA! Quality! He could have also just used 1 and a half rover HG's! Right.. Without that welsh git bitching on about dodgy mechanics and beating us Scots in the rugby my personal suggestion would be to just buy a new engine. There are plenty on here going stupid cheap! (Infact, I could get you one for literally peanuts!) Would take someone with very little mechanical knowledge and and decent socket set a good days work. So your a drifter? Would that have anything to do with you blowing up a bullet proof engine!! Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 HAHAHA! Quality! He could have also just used 1 and a half rover HG's! Right.. Without that welsh git bitching on about dodgy mechanics and beating us Scots in the rugby my personal suggestion would be to just buy a new engine. There are plenty on here going stupid cheap! (Infact, I could get you one for literally peanuts!) Would take someone with very little mechanical knowledge and and decent socket set a good days work. So your a drifter? Would that have anything to do with you blowing up a bullet proof engine!! ill see how this pans out but i may take you up on that engine offer and yeh i have a habit of looking out the side window to see where am going.like it says bellow IF IN DOUBT HANG IT OUT. Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 12, 2011 Share Posted February 12, 2011 ill see how this pans out but i may take you up on that engine offer and yeh i have a habit of looking out the side window to see where am going.like it says bellow IF IN DOUBT HANG IT OUT. Get a decent engine then NA-T it, speak to Suprash, our resident BDC drifter, thats what he runs, fantastic car and sounds amazing. Fitted his engine and box in no time! Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 Get a decent engine then NA-T it, speak to Suprash, our resident BDC drifter, thats what he runs, fantastic car and sounds amazing. Fitted his engine and box in no time! i looked in to the n/a-t rought a while back costs a bloody fortune for the kits. Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 12, 2011 Share Posted February 12, 2011 i looked in to the n/a-t rought a while back costs a bloody fortune for the kits. Speak to Ash mate, he did it on a tiny budget and it worked for him! At worst he'll give you a ball park figure to aim for! Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 Speak to Ash mate, he did it on a tiny budget and it worked for him! At worst he'll give you a ball park figure to aim for! sound mate will give ash a shout.and quality Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 12, 2011 Share Posted February 12, 2011 sound mate will give ash a shout.and quality He is only round the corner to me, JustGav in my next door neighbour and between us and AFR (Dude and Matt) he's finally got a reliable running car... He'sgone through about 3 engines to get it right. But so far so good.. (touches wood) he is up and running ready for the next season! (Early, for the first time ever!) Quote Link to comment Share on other sites More sharing options...
sim1987 Posted February 12, 2011 Author Share Posted February 12, 2011 i just want the car to be able to smoke just about anything in front of me and then laugh as i overtake then sideways(party trick i pull on my mates looks good on camera). Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 12, 2011 Share Posted February 12, 2011 i just want the car to be able to smoke just about anything in front of me and then laugh as i overtake then sideways(party trick i pull on my mates looks good on camera). Then start saving... You'll be looking for big HP and getting a decent diff (and the rest).. We have a name for that sort of power.. It's called JamieP!! Quote Link to comment Share on other sites More sharing options...
