JohnA Posted June 24, 2005 Share Posted June 24, 2005 Anybody know how to fix this? I accidentally chopped off the (plastic!!) nipple that holds the tiny hose that goes to the IACV actuator Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 24, 2005 Author Share Posted June 24, 2005 I've tried sticking it back with a glue gun, but I'm not sure I trust it to withstand boost and heat. My EPC doesn't work, can someone please verify that the number is 90910-12126B? That's what I think it says on the outside (not clear) Quote Link to comment Share on other sites More sharing options...
colsoop Posted June 24, 2005 Share Posted June 24, 2005 Hi there i checked my parts catalogue and the part no doesn't exist! I looked through the catalogue and it is hard to tell which is the part you need. See attached picture I have a spare set of pipes and the part you need is attached to the very top isn't it (17321 c) The description for this is duct air outlet No1 - not clear is it? I happen to have that little plastic bit spare if you need it? Quote Link to comment Share on other sites More sharing options...
Wez Posted June 24, 2005 Share Posted June 24, 2005 Sounds painful Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 24, 2005 Author Share Posted June 24, 2005 Hi there i checked my parts catalogue and the part no doesn't exist! I looked through the catalogue and it is hard to tell which is the part you need. See attached picture I have a spare set of pipes and the part you need is attached to the very top isn't it (17321 c) The description for this is duct air outlet No1 - not clear is it? I happen to have that little plastic bit spare if you need it? The VSV is not in that diagram. It is connected to the actuator that can be seen in the highlighted area in your diagram though. Quote Link to comment Share on other sites More sharing options...
