Diagnostics not working?!?
CanisLupus
Hi guys.
Because of some missfire and idle problems i wanted to check for fault codes.
So connected TE1 and E1, switched igntion on(alarm was disarmed) and... nothing. The CEL light didn't flash at all.
Tried several times and nothing changed.
I know this worked because i checked codes few months ago. Some ideas why it doesn't anymore?
No changes in ECU, Alarm or other things i could think of. :(
Car: 1996 TT RZ BPU
Edited by CanisLupus
Didn't mean the big red ! but the orange CEL not flashing. (see edit history)
Thanks for the tip. Forgot to mention but i've soldered everything back then when i needed the diagnostics and realised some of the lights weren't working as intended.
All lamps are working fine(CEL, Oil Level, Oil Pressure). Or could dry joints come back after a few months and manifest in a non flashing CEL which is lighting up?
It just won't flash when i bridge TE1 and E1 :(
Edited by CanisLupus (see edit history)
