bigjools Posted February 12, 2011 Share Posted February 12, 2011 (edited) hi all is anyone in notts ive got jspec tt auto its now decated still to fit fcd /boost gauge and still to find ebc fuel pump air fillter plugs i think thats it to reach bpu but what i could do with is someone close to have a go in it to see if everything is comming on as it should any help would be great thanks all forgot ive got 1st &2nd decats with rr + old exhaust with cats if any wants to swop for bits i need cheers for help Edited February 17, 2011 by bigjools (see edit history) Quote Link to comment Share on other sites More sharing options...
sams Posted February 12, 2011 Share Posted February 12, 2011 im south lincs (40ish mile away), i just finishing the bpu mods (fcd is all thats left) to my jspec auto tt, i assume you have decats and checked the condition of the intercooler? Quote Link to comment Share on other sites More sharing options...
bigjools Posted February 12, 2011 Author Share Posted February 12, 2011 i did not no had to check the intercooler how do you do that and yes its decated Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2011 Share Posted February 12, 2011 Do you have a restrictor ring fitted to keep the boost down, j specs can overboost without one Quote Link to comment Share on other sites More sharing options...
Nic Posted February 12, 2011 Share Posted February 12, 2011 i did not no had to check the intercooler how do you do that and yes its decated If you have the stock side mounted intercooler fitted look in the drivers side opening in the front bumper, check the condition of the cooling fins if they are missing, corroded and crumbling to the touch then it could really do with replacing. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted February 12, 2011 Share Posted February 12, 2011 Do you have a restrictor ring fitted to keep the boost down, j specs can overboost without one Quote Link to comment Share on other sites More sharing options...
bigjools Posted February 12, 2011 Author Share Posted February 12, 2011 restrictor ring fitted and going out to check fins thanks all so far Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2011 Share Posted February 12, 2011 Good luck with the intercooler, most are in a poor state after 10 + yrs Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted February 12, 2011 Share Posted February 12, 2011 If it were me, a new FMIC would be high on my list if i was going to be running 80bhp odd more that MrT intended, on a 10+ year old car. They're not even that dear. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 12, 2011 Share Posted February 12, 2011 If it were me, a new FMIC would be high on my list if i was going to be running 80bhp odd more that MrT intended, on a 10+ year old car. They're not even that dear. I wouldn't advocate a cheap FMIC, they are likely to be lot less efficient than a brand new stock or good quality aftermarket side mounted intercooler. If you do fit an FMIC then get a good quality one - expensive - and make sure it is properly ducted so the air is forced to pass through it. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted February 12, 2011 Share Posted February 12, 2011 (edited) I wouldn't advocate a cheap FMIC, they are likely to be lot less efficient than a brand new stock or good quality aftermarket side mounted intercooler. If you do fit an FMIC then get a good quality one - expensive - and make sure it is properly ducted so the air is forced to pass through it. I said they weren't that expensive, not buy a cheapo one. Edit: Whiftbitz FMIC Perfect for what you need and only £360inc VAT Edited February 12, 2011 by SupraDan24 (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted February 12, 2011 Share Posted February 12, 2011 I said they weren't that expensive, not buy a cheapo one. Isn't that the same thing, I'd class the one you posted as cheap. With intercoolers you tend to get what you pay for in terms of quality and efficiency. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted February 12, 2011 Share Posted February 12, 2011 No not really, its all relative. Not everyone needs to go buy a £1200 Blitz one. Your idea of cheap may be completely different to mine, a cheap no brand ebay jobby is what i was referring too. That one is a Garage Whifbitz FMIC, good for up to 550bhp and seeing as Paul is selling it, its going to be good quality. He's going BPU, that FMIC is more than adequate. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 12, 2011 Share Posted February 12, 2011 Im inLincoln if you want to pop up. If you havent got the bits whats the point on checking the progress lol Quote Link to comment Share on other sites More sharing options...
bigjools Posted February 14, 2011 Author Share Posted February 14, 2011 intercooler is i think no good bits ov the fins just fall off so this may take more time and money but do i do the rest first or intrercooler Quote Link to comment Share on other sites More sharing options...
Nic Posted February 14, 2011 Share Posted February 14, 2011 intercooler is i think no good bits ov the fins just fall off so this may take more time and money but do i do the rest first or intrercooler You can fit the parts but I would keep the boost down to stock levels - using the restrictor ring - until you have replaced the intercooler. Even at stock boost levels you should feel the turbos spin up quicker without the cats. Quote Link to comment Share on other sites More sharing options...
bigjools Posted February 17, 2011 Author Share Posted February 17, 2011 could still do with someone to have a drive just to c how iam going thankyou all Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 17, 2011 Share Posted February 17, 2011 You will save a bit by not fitting an EBC. You dont really need one normally on BPU. Quote Link to comment Share on other sites More sharing options...
bigjools Posted February 17, 2011 Author Share Posted February 17, 2011 thankyou all 4 your help i just want the best and iam getting it from all ov you cheers Quote Link to comment Share on other sites More sharing options...
AndyT Posted February 17, 2011 Share Posted February 17, 2011 Do it right don't ruin your car. That's what I do. Slowly. I don't like having to put cats back for MOT, don't need both so one sports job will do it. All legal no probs. Quote Link to comment Share on other sites More sharing options...
bigjools Posted February 17, 2011 Author Share Posted February 17, 2011 so will ebc make any diffrence can i have + or - effect ??? thanks Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 17, 2011 Share Posted February 17, 2011 EBC can only increase boost, but full BPU will be at a safe 1.2 bar without it. EBC cant lower boost. Quote Link to comment Share on other sites More sharing options...
