Piston size
Guest joey
Hey all,
Does anyone know the size of 2jz-ge & 2jz-gte pistons, as in width & depth.
You can all probably guess what im getting at, putting a set of forge gte pistons in my ge once ive finished the turbo conversion.
Cheers all
The crank and rods are more than just dimensionally the same, they are exactly the same, same part numbers. :) If you are buying new pistons it would be madness to put them in old bores,, rebore it first over size, which is 86.5 mm or 87 mm depending on piston make and availability. I like Wiseco for a good piston on a budget.
