Crazybassist Posted February 11, 2011 Share Posted February 11, 2011 Right first off, sorry about this thread, as I'm sure this has been covered literally hundreds of times. But I have found so many different ideas on where to stick these damn things I thought it best to check. I got this MBC off of ebay the other day, and as far as I can make out it's a ball and spring relieving type mbc. I've plumbed it in from the wastegate vsv to the actuator, as this seemed to be the most sensible of all the other ideas I'd found. I cant take the car out for a spin myself to test it as its on a sorn at the mo, and I'm currently a month off getting my license back but I did get the old man to take it for a quick spin in the village and all seems well. Just needs adjusting to give me 1.0 bar. If this is right then hopefully others can use the pic I've posted to get an idea for themselves. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2011 Share Posted February 11, 2011 No, wrong place bud. You are on the wrong part of the actuator, on your pic you can see the one you should be between just above that. Where is the other end of the MBC going? Into the VSV? What guide did you follow? Not sure if you have the correct understanding of how this system works but you shouldn't be anywhere near the VSV with a boost controller. Quote Link to comment Share on other sites More sharing options...
Crazybassist Posted February 11, 2011 Author Share Posted February 11, 2011 No, wrong place bud. You are on the wrong part of the actuator, on your pic you can see the one you should be between just above that. Where is the other end of the MBC going? Into the VSV? What guide did you follow? Not sure if you have the correct understanding of how this system works but you shouldn't be anywhere near the VSV with a boost controller. I have to be honest, I aint that experienced with anything turbo. Is this where it should be (see attached) Quote Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2011 Share Posted February 11, 2011 Yup, you replace that wee pipe with the MBC. The rest of it stays exactly as it was, the VSV still connects to the elbow port as it did before etc. Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted February 11, 2011 Share Posted February 11, 2011 The hose coming off the actuator was blocked off on mine. Saw a diagram on here saying to do that too. Post 5 2nd picture That was a EBC rather than MBC though. They different? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2011 Share Posted February 11, 2011 The hose coming off the actuator was blocked off on mine. Saw a diagram on here saying to do that too. Post 5 2nd picture That was a EBC rather than MBC though. They different? Yup, the EBC is far better at keeping the boost linear. The VSV that you have blocked off fluctuates the actuator to help control it and hold it closed for pre-spooling purposes. Not sure if blocking it off would make any difference with an MBC, but there is no "gain" control.... I think this is what that particular vsv basically does. Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted February 11, 2011 Share Posted February 11, 2011 Ah ok. I'm not going to pretend I know how it all works lol I took it off and sold it anyway. Quote Link to comment Share on other sites More sharing options...
Crazybassist Posted February 11, 2011 Author Share Posted February 11, 2011 Yup, you replace that wee pipe with the MBC. The rest of it stays exactly as it was, the VSV still connects to the elbow port as it did before etc. Cheers mate. At last a clear picture as to where to put the damn things Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 11, 2011 Share Posted February 11, 2011 And when you can afford it, get a nice electronic boost controller Quote Link to comment Share on other sites More sharing options...
Mistermann Posted February 14, 2011 Share Posted February 14, 2011 I have to be honest, I aint that experienced with anything turbo. Is this where it should be (see attached) I have just stuck mine in and plumbed it into this pipe. the third outlet from the MBC -The bit that opens as you unscrew it, does that need to be attached to anything or can you just let it vent the excess off into the atmosphere? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2011 Share Posted February 14, 2011 I have just stuck mine in and plumbed it into this pipe. the third outlet from the MBC -The bit that opens as you unscrew it, does that need to be attached to anything or can you just let it vent the excess off into the atmosphere? That is a bleed valve, nothing needed to connect to it. Best to get shot of it though as they are very unreliable. Quote Link to comment Share on other sites More sharing options...
Mistermann Posted February 23, 2011 Share Posted February 23, 2011 as i found out after a very short drive after putting it in...have taken it out again now! Quote Link to comment Share on other sites More sharing options...
