Built engine what parts to go for?
Oddball87
  • Replies 53
If 600 BHP isn't enough I would say some horses may be lame.... Have you had it on a hub type rolling road dyno?
It was last mapped at TDI whom i believe use a hub dyno. It uses tones of fuel which i put down to the 1000cc injectors but i heard from my mate that the emissions are supposed to be absolutly dreadful! The only problem is the clutch started to give up! I've started to collect parts for my build (whole new engine) which includes a twin plate carbonetic clutch,Due to building a whole new engine i was thinkin of reconditioning my HKS GD pro clutch for the current engine then having the map checked. I'm going to swap to the syvecs system i think though so checking the map is only a check, remapping may be left till the swap!
