ripped_fear Posted April 29, 2012 Author Share Posted April 29, 2012 Just bought myself a 6 speed clutch res, just for the heat sheild lol so I can polish it up. Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted April 29, 2012 Share Posted April 29, 2012 shiny shiny Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 29, 2012 Author Share Posted April 29, 2012 shiny shiny had no luck finding the shield itself so needs must Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 30, 2012 Author Share Posted April 30, 2012 Got the new gloss black dizzy on today, also started on the number plate surround, Just needs a bit of sanding to get it perfect then its off for paint. Also ordered a new set of front brake pads and a vac hose which I noticed today has a small split in it. Then spent the afternoon cleaning the engine bay up, and its all shinny again now. No pics Im afraid seem to have lost my camera. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 1, 2012 Author Share Posted May 1, 2012 Got the numberplate surround finished today, very happy with it just need to paint it now. Also got some pictures of yesterdays work, with the dizzy all fitted. And finally a nice pile going on the car tomorrow Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted May 1, 2012 Share Posted May 1, 2012 looking good mate, get that tensioner polished up:p Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 1, 2012 Author Share Posted May 1, 2012 looking good mate, get that tensioner polished up:p Cheers bud I should I have had it polished up, but haven't the time now, need it fitted ASAP. Im again considering the NA-T option and if I do I will do all the pulleys Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted May 1, 2012 Share Posted May 1, 2012 Cheers bud I should I have had it polished up, but haven't the time now, need it fitted ASAP. Im again considering the NA-T option and if I do I will do all the pulleys Thats what I like to hear mate:) I think your car deserves a turbo:eyebrows: Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 2, 2012 Author Share Posted May 2, 2012 Got the engine oil and filter, gearbox oil all done today. Best of all the tensioner is on so no more rattle! Also got a clutch res through ready for the shiny treatment. And a few bit are of to the paint shop tomorrow Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 3, 2012 Author Share Posted May 3, 2012 More progress. -Got some new front brake pads from Toyota -New vac hose from Toyota -Painted the Clutch res cap -Polished the clutch res heat shield -Painted some more stock air box clips -Painted the Number plate surround matt black Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 4, 2012 Author Share Posted May 4, 2012 Vac hose, Clutch res cap, and the Painted air box clips all fitted now. Also turned all the clips so the bolts where not on show so it look cleaner, Unfortunately the polished res shield may prove a problem as my car doesn't seem to have the bolt holes so going to have to retro fit it. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted May 4, 2012 Share Posted May 4, 2012 Just change the master cylinder to the turbo one you got? That obviously has the bolt holes in it Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 4, 2012 Author Share Posted May 4, 2012 Just change the master cylinder to the turbo one you got? That obviously has the bolt holes in it Indeed I could do this, would it require much work to change? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted May 4, 2012 Share Posted May 4, 2012 Pull out a pin that joins the master rod to the clutch pedal, a simple r-clip holds it together. Then two nuts hold the master to the baulkhead, under the dash. The all you have to do is disconnect the clutch fluid line and re/bleed it after. 30 mins work Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 4, 2012 Author Share Posted May 4, 2012 Pull out a pin that joins the master rod to the clutch pedal, a simple r-clip holds it together. Then two nuts hold the master to the baulkhead, under the dash. The all you have to do is disconnect the clutch fluid line and re/bleed it after. 30 mins work Cheers for the input mate might just do that then. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted May 4, 2012 Share Posted May 4, 2012 are the clutch masters for the 5 speed and 6 speed the same then? I would have thought they would be different bore sizes etc I would check they are the same part numbers I maybe wrong but worth checking out Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 6, 2012 Author Share Posted May 6, 2012 (edited) Impulse buy, just bought a set of supra spacers on the hope they don't push my wheels out too far. And some new material for the exhaust surround too. Edited May 6, 2012 by ripped_fear (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted May 6, 2012 Share Posted May 6, 2012 bay looking sweet. you going to paint the dizzy main unit? that would look nice. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 8, 2012 Author Share Posted May 8, 2012 bay looking sweet. you going to paint the dizzy main unit? that would look nice. I think I will yeah, going to do a few more bits too, going to paint the bay 199 instead of the primmer but not for a few weeks yet. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 10, 2012 Author Share Posted May 10, 2012 New wrap has arrived along with my spacers. Roll on sunday. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 14, 2012 Author Share Posted May 14, 2012 Worked non stop yesterday on the car, First off tried to fit the spacers and they turned out to be no good as the stock studs pertrude out the front of the spacer therefore stopping me from fitting the wheel. Next the new wrap for the exahaust surround was awful stuff to wrap anything that wasnt flat so that was no good either. So to keep my spirits up I bonded the clutch res heatsheild on and left it over night to set today its rock solid and looks great. No pics as its raining now and dont want to go outside Next I gave the car a full clean, apart from under the hood. Washed it using loads of liquid wax and rinsed down, then dried her off and left it to stand so it was bone dry. Then pannel wiped the whole car down removing all the old rubbish, tar, salt and wax off it. And proceeded to do 3 stages of wax. I compounded the rear bumper and waxed it up, then touched up a couple of stone chips. Gave it a final wipe down and then did the interior and glass. The final result was as followed. Please ignore the tape on the steering wheel, its there to remind me in the morning to remove the tape holding the heat sheild in place. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 14, 2012 Author Share Posted May 14, 2012 Also just got a chrome batter bar, so I can say good by to my polished one And trying to get my decal cut for my number plate surround. PLUS got some new ideas for under the bonnet so once back from dragonball the NA bay is going to get some more work! Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 16, 2012 Author Share Posted May 16, 2012 this will be the last update for a bit, as she is off on dragonball tomorrow! :yahoo: Got the graphics ariving from the designers for the numberplate surround, plus got my chrome batter bar today. And that me done for a few days. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted May 23, 2012 Author Share Posted May 23, 2012 Well may aswell update this, car made the dragonball but not without its problems- CLICK Also here is some picks of the number plate surround finished and if you look closely in the other picture you can see the clutch res heat sheild, and chrome battery bar. Quote Link to comment Share on other sites More sharing options...
Noz Posted May 23, 2012 Share Posted May 23, 2012 Looking mint under there Jakey boy. Quote Link to comment Share on other sites More sharing options...
