coolant suggestions?
stu861
if antifreeze is antifreeze, how come toyota do a red and a blue that don't mix?
They also do a pink as well that i've been told you should not use in a mkiv.
Im not sure whats in the Cool Red but could it be similar to the opie oils one listed above and is a 50% mix with distilled water, much better imo than a mix with tap water.
I've not used anything else in my car and for the sake of £25 i shan't be changing
I suspect one is a so called "long life" version IE silicate free antifreeze, which can cause sludge problems if used for extended periods,some are supposed to have additive's that coat all aluminum blocks to prevent corrosion, but in any case antifreeze should be changed every two years anyway, so its up to you if you want to pay four or five times the price for the same thing;)
Oh! and Toyota don't actually make antifreeze, it just proprietary re branded stuff;)
This has all been done before, have a search.
