Suprab1 Posted February 8, 2011 Share Posted February 8, 2011 I was looking on ebay & found these. They seem perfect for the supra but with its big nose i wonder would it go up as easy as an mx5? Anyone one here seen or used these? http://cgi.ebay.co.uk/Sports-car-long-low-angle-lifting-Ramps-2000Kg-a-pair_W0QQitemZ120320381749QQcategoryZ108783QQcmdZViewItemQQ_trksidZp4340.m8QQ_trkparmsZalgo%3DMW%26its%3DC%26itu%3DUCC%26otn%3D5%26ps%3D63%26clkid%3D6948787628723011782 Link to comment Share on other sites More sharing options...
Dnk Posted February 8, 2011 Share Posted February 8, 2011 My car definetly wouldn't go up those with the TRD front on it and lowered on Eibachs Link to comment Share on other sites More sharing options...
Josh Posted February 8, 2011 Share Posted February 8, 2011 I'd like to buy some ramps. They look pretty good Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2011 Share Posted February 8, 2011 I have a set, i can reverse up on them with ease, have to use some wood to get the front on them. Link to comment Share on other sites More sharing options...
ripped_fear Posted February 8, 2011 Share Posted February 8, 2011 they look ok mate but be warned, enven ones like these with the gentle slope can still prove a problem for some cars and although i can not coment on these particular ramps i have one very similar and with an rmm lip on stock brings i can only just get up it. EDIT-seem like they will be fine lol Link to comment Share on other sites More sharing options...
merckx Posted February 8, 2011 Share Posted February 8, 2011 We've got a set, they're great. Straight up without using any extra pieces of wood. Link to comment Share on other sites More sharing options...
heckler Posted February 8, 2011 Share Posted February 8, 2011 I have those, my car has TS Bumper and tein coil overs, and I can drive up up the ramps, with the front wheels butted up to the ramps theses an approximate gap of 5mm between the ramps and bottom of bumper. It never scrapes Link to comment Share on other sites More sharing options...
Suprab1 Posted February 8, 2011 Author Share Posted February 8, 2011 I have a set, i can reverse up on them with ease, have to use some wood to get the front on them. http://i30.photobucket.com/albums/c338/jamie450x/exhaust010.jpg They get your car up a nice hight for working on Jamie. Is the front near the ground when you have it like that? We've got a set, they're great. Straight up without using any extra pieces of wood. Just what i wanted to hear . Might just order myself aset now. Link to comment Share on other sites More sharing options...
Suprab1 Posted February 8, 2011 Author Share Posted February 8, 2011 I have those, my car has TS Bumper and tein coil overs, and I can drive up up the ramps, with the front wheels butted up to the ramps theses an approximate gap of 5mm between the ramps and bottom of bumper. It never scrapes In that case mine should fly up these. I have a set out of halfords but i have to put wood infront of them even for a seat inca van. Just need something to get cars up (including my Supra) until i get my 2 post lift. Link to comment Share on other sites More sharing options...
imi Posted January 2, 2012 Share Posted January 2, 2012 Seen these ones on Ebay http://www.ebay.co.uk/itm/310352398792?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1654wt_1052 most ramps tend to be quite narrow, would they damage a wider tyre if it were to over hang on either side? the ones that jamie has look very good however these ones on ebay are far steeper, I am wondering whether the supra will struggle to reverse onto these. the plan is the reverse the car onto the ramps and then lift it on axle stands in the front. Link to comment Share on other sites More sharing options...
peter richards Posted January 2, 2012 Share Posted January 2, 2012 should be easy to make , only small angle iron and a bit of cutting and welding Link to comment Share on other sites More sharing options...
Morpheus Posted January 2, 2012 Share Posted January 2, 2012 Seen these ones on Ebay http://www.ebay.co.uk/itm/310352398792?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1654wt_1052 most ramps tend to be quite narrow, would they damage a wider tyre if it were to over hang on either side? the ones that jamie has look very good however these ones on ebay are far steeper, I am wondering whether the supra will struggle to reverse onto these. the plan is the reverse the car onto the ramps and then lift it on axle stands in the front. I have the same ones JP has. They're 6 feet long and plenty wide enough not to do any damage to tyres, though not ideal, obviously. Still much wider than the cheap steep ones though at 10 inches. Reversing up, you'll completely reduce clearance at the front to raise the car so you'll need two scissor jacks as well; one for each side behind the front wheel under the cill. Edit:- The 1st post eBay link is still valid and has full details. They're very heavy and solidly built, not like the cheaper ones but they don't fit inside one-another so you'll need about 2 square feet for storage, upright. Link to comment Share on other sites More sharing options...
merckx Posted January 2, 2012 Share Posted January 2, 2012 Edit:- The 1st post eBay link is still valid and has full details. They're very heavy and solidly built, not like the cheaper ones but they don't fit inside one-another so you'll need about 2 square feet for storage, upright. I also have them. They won't damage the tyres, it's nothing compared to what conditions the tyres are designed to withstand on the road. Link to comment Share on other sites More sharing options...
peter richards Posted January 2, 2012 Share Posted January 2, 2012 £160 , as i said i could make these no problem , steel is expensive atm , but if you guys want i can look into it , im sure i can make them for less than that price Link to comment Share on other sites More sharing options...
ashbuster Posted January 3, 2012 Share Posted January 3, 2012 i would be interested bud Link to comment Share on other sites More sharing options...
Josh Posted January 3, 2012 Share Posted January 3, 2012 £160 , as i said i could make these no problem , steel is expensive atm , but if you guys want i can look into it , im sure i can make them for less than that price I'd be interested too. I don't like getting under the car just being held by a trolley jack and axle stands, I'd much prefer ramps. Link to comment Share on other sites More sharing options...
Noz Posted January 3, 2012 Share Posted January 3, 2012 Me too, I would be interested in seeing dimentions first though, as I can't get a standard jack under my car, only the toyota jack that came with the car will go under it, as trolly jacks won't fit. Link to comment Share on other sites More sharing options...
fastcar Posted January 3, 2012 Share Posted January 3, 2012 +1 for me they are a good ramp light but very strong and never have a problem getting the front of the car on them. Link to comment Share on other sites More sharing options...
peter richards Posted January 3, 2012 Share Posted January 3, 2012 ok , ill see if jamie can give me some dimensions from his , i can work out how much angle iron ill need and the cost of it . probably going to need at least 5 sets to make it worth doing and ill run it by the mods just to be le git Link to comment Share on other sites More sharing options...
SPG Posted January 3, 2012 Share Posted January 3, 2012 I would take a set too Link to comment Share on other sites More sharing options...
JamieP Posted January 3, 2012 Share Posted January 3, 2012 ok , ill see if jamie can give me some dimensions from his , i can work out how much angle iron ill need and the cost of it . probably going to need at least 5 sets to make it worth doing and ill run it by the mods just to be le git Im out in the garage tomorrow mate, will get something together. Link to comment Share on other sites More sharing options...
peter richards Posted January 3, 2012 Share Posted January 3, 2012 thanks mate just sent you a pm Link to comment Share on other sites More sharing options...
Josh Posted January 3, 2012 Share Posted January 3, 2012 ok , ill see if jamie can give me some dimensions from his , i can work out how much angle iron ill need and the cost of it . probably going to need at least 5 sets to make it worth doing and ill run it by the mods just to be le git How wide would you be thinking of making them? Link to comment Share on other sites More sharing options...
peter richards Posted January 3, 2012 Share Posted January 3, 2012 see what width comes back when jamie measures them i can make them a bit wider if need be Link to comment Share on other sites More sharing options...
JamieP Posted January 3, 2012 Share Posted January 3, 2012 My car is sat on them, best i can do at the min. Link to comment Share on other sites More sharing options...
