Are Facelift speedo/Tachometer the same as pre-facelift?
SupraDan24
Is there any difference between the Facelift and Pre-facelift Speedo and Tachometer? I know the PCB's are different, but does that effect the clocks themselves? Also, i have the 320mph TRD clocks, when i remove these and stick the OEM ones in, will the OEM ones need to re-calibrated in anyway? Lastly, my TRD's have the mileage on them as aposed to using the digital. How do i transfer it back to the digital?
Dan
Guest GT twinturbo
do not think the facelift speedo fits non-facelift. since the non-facelift is digital and the facelift has analog trip count.
I installed TRD 320km/h speedo, I just plugged it in and everything worked fine :)
I do not know about the tachometer... believe it is similar?:rolleyes:
I have a 96 TT J-spec facelift :)
Guest GT twinturbo
I dont think it will work?:(
I dont think the wiring is the same??
but you can try:)
Think you have to use every thing from the pre-facelift:rolleyes:
