Guest wantthatone Posted February 4, 2011 Share Posted February 4, 2011 has anyone bought the a pillar 2 gauge pods from ebay, its the actual trimt hat goes along the roof line as well. if so do you do away with the original trim? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 4, 2011 Share Posted February 4, 2011 Yep. I stuck mine on with silicone. Was hard to keep it positioned tho Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted February 4, 2011 Share Posted February 4, 2011 what was the finished out come? Quote Link to comment Share on other sites More sharing options...
David P Posted February 4, 2011 Share Posted February 4, 2011 Just be sure that you can live with LED torches shining into your eyes whilst night driving, before even considering a pillar pod. Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted February 4, 2011 Share Posted February 4, 2011 it arrived today. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 4, 2011 Share Posted February 4, 2011 Just be sure that you can live with LED torches shining into your eyes whilst night driving, before even considering a pillar pod. My defi gauges (White) that are black when turned off are not bright at all. Just right. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted February 5, 2011 Share Posted February 5, 2011 I have one, not fitted it yet but the quality is great. Link the dials in to the same power as the rest of the dash so you can dim them, should be fine. Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted February 5, 2011 Share Posted February 5, 2011 My defi gauges (White) that are black when turned off are not bright at all. Just right. same here. Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted February 6, 2011 Share Posted February 6, 2011 just thought i would update this, the gauges i am using are 52mm, i was unsure where to fit the 3rd, after looking at the dash air vents, i made my mind up, this is where it has to go! i had read this is a common place for the 60mm, so debating it i decided to take the vent out easy enough, but there was a lot of play with the 52mm gauge & the vent, anyway took the vent to pieces, what a great bit of design & engineering! the vent now just a void, opened the gauges it came with a visor of some sort. fitted this onto the gauge, now this was the correct diameter! put this into the empty vent housing & perfect!!!! Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 6, 2011 Share Posted February 6, 2011 Mine was like that but I wanted the vent back Quote Link to comment Share on other sites More sharing options...
jackso11 Posted February 6, 2011 Share Posted February 6, 2011 Mine was like that but I wanted the vent back mine too Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted February 6, 2011 Share Posted February 6, 2011 thats what i meant, im using the vent shell, so i can still rotate move etc, looks the business Quote Link to comment Share on other sites More sharing options...
