A/f Readout
BROARDSIDE
  • Replies 65
:eek:
Take a step back mate, can you give us the full spec of the car as it will stand once you've fitted everything you've got already.
Knock Amps won't tell you your AFR's you need an AEM or similar AFR gauge with sensor. The sensor has to be mounted in the exhaust.
And stop using CAPS! :)
oh let the caps thing go :)
:shrug: :shrug:
ok i have a n/a witch is soon to changed to an na-t
using a boostlogic stage 2 turbo conversion kit
Boost Logic 321SS Tubular Manifold 1 5/8” Tubing and 1/2” Thick 321SS Flanges
(Turbo’s with a 4” inlet clears the distributor. Manifold fits a turbo up to a T76)
Boost Logic Spec T4 Turbo
HKS 40mm Wastegate
3” SS304 Polished Downpipe w/ Flex Joint
3” SS304 Polished Midpipe
SS304 Polished Dump Tube
3” Polished Aluminum Intake Pipe
Boost Logic FMIC Kit
2 ½” Polished Aluminum IC piping
4 Ply Silicone Hose Connectors
Stainless Steel Hose Clamps
Boost Logic NA-T SS Braided Oil Feed and Return Kit w/ Aeroquip fittings
3” K&N Filter (soon to be for sale)
K&N Breather for PCV Valve
Walbro GSS341 255HP Fuel Pump w/ Install Kit
Stage II Upgrades
Boost Logic 2.5mm Head Gasket
440CC Injectors x 6 (fits in the stock rail)
Injector Piggy Tails x 6
fitted now:::
blitz nurspecR exhaust
apexi induction
apexi safcII
wizards of noS kid (75 shot)
now before the kit is fitted i just want to setup the gauges inside the car
im gonna want:
oil pressure
oil temp
boost pressure
a/f ratio
possibly fuel pressure
not sure of any other considerations :thanks:
You'll need to state which ECU you are planning on using.
Also I'm pretty sure 440cc injectors are going to be too small for an Na-T conversion.
Edited - just spoted the SAFC2 listed! I think you'll need a boost controller too.
He did, SAFCII, piggybacking the stocker.
440's will be fine as long as he's not going for mega boost. Anything over 400bhp you can forget about.
Then returning to the question, I use an AEM 52mm AFR gauge with AEM WB02 sensor plumbed into the exhaust.
What pressure is the spring in the wastegate...EBC not needed IMO if the spring is properly rated.
SAFC wouldn't be up to job I wouldn't have thought...
Emanage with a pressure sensor so you can control the fueling perhaps?? (I could be talking complete bollocks tho as well, since I gave up on the NA-T route)
Also I would careful of using the nitrous, since I assume you are using stock box, and stock diff... they might be the weak point of the whole setup
Gav
Guest Terry S
I think the NA's run 380cc injectors, and I also believe they are top feed so the 440's wont fit the rail. Not 100% on all that though
They are 370cc I think, can't recall if there is a difference in the rail layout though. I don't think there is as I've looked at Digsy's NA engine a few times and I can't recall going "blimey - that's different" at the fuel rail.
-Ian
That'd work, pull the airflow signal right back to compensate for the bigger injectors, then use the addinj map to add duty cycle when on positive boost. Could work rather well :)
-Ian
I do come up with some interesting ideas once in a while...
I'm actually considering install an emanage onto a bike when I do a turbo installation on it... either that or on a morris minor I've just bought for a laugh...
Morris minor with a single toyota turbo.... could be a laugh...
Gav
what the F**K have you lot just said :giveup: im not as clued up as i should be but im getting there the way i see it is the whole thing comes as a kit so im hoping for initial setup to be ok then i can start playing with boost controllers and shi* like that but if i just get a wide band 02 sensor then i can adjust the fueling with the SAFC2 that i have got installed
i cant see any point in buying a e-manage controller as the mapping will only do the same sort of thing as the SAFC 2 (obviousley with more acurate results )
what u think talking sh** or am i on the right lines
I really don't mean to cause offence but either:
- the people you are talking to don't know what they're selling
or
- you are just taking too simplistic view of tuning (Or have little experience of it). Converting an NA to a turbo is not a matter of just bolting on bits from an "NA-T parts pack"
Rather than let this thread drag on for ages with people explaining every aspect of single turbo conversions, I highly recommend you give Terry S (Vortex) a call tomorrow. Terry or one of the guys there will be able to discuss your requirements in much more detail than is possible on a forum. They've done numerous single conversions and have a kit for an NA too.
Not sure about that CJ, I doubt Terry would recommend a T4 turbo (laaarge) with 75 shot NOS and 440cc injectors! Why bother with NOS if you're going for a low boost big size turbo... It just looks like a total mis-match of parts.
:run:
Option a) for me.
The sAFC cannot do anything other than change the airflow signal to move where you are on the fuel map. The NA supra ECU has no map for positive pressure and there is no sensor in the system to measure positive pressure so when you go on boost your MAF sensor will go out of range very quickly and christ knows how much duty cycle it will run - maybe 100% as it thinks it's a gorilla 3.3l at 1000ft below sea level for a moment, but that's the end of it's range. Good luck in trying to get any meaningful fuel-to-boost-pressure curve out of that. Harsh words maybe, but couple the inability to map fuelling when on boost (a bit of a disaster when you are adding a turbo) with too-small injectors and too-large a turbo, and you are putting together an expensive boat anchor... My advice is, do a lot of reading and a modicum of planning before any spending.
-Ian
or
yeh sorry i thought that was the point of the forum was to ask questions and resolve things. . . . also so some of the other members of the forum who are not so clued up as you are but dont wanna look stupid by asking get to read the responses if they think are thinking of doing the same thing
Hi Broadside, like I said, I really didn't mean to cause offence or anything. Since you seem to be quite new to modifying forced induction cars and clearly have very big plans for your Supra, you're really best of speaking to one of the 'real' experts (After all you don't want to bolt anything on and find your engine going 'pop')
Terry S and the rest of the Vortex lads know their stuff so you're really best off speaking to one of them first so they can set some basic ideas about tuning your cars. Have you spoken to them yet mate?
Here is the kit list from someone on supraforums who has done it...
TO4E-60 - $620 used
Fmax manifold- $820 new
intercooler pips - $20 (hookup from Mike) 3 u bends
S-afc - $320 new
VPC- $500 new
oil lines- $45 new
oil union bolt-$35 new
TT-intercooler- Free(hookup from in-laws)
TT-Fuel pump- $80 use
440 injectors- $330 ( from Dave H)
welding works-$200 service
Gav
A bit of a :hijack: but are there any differences in the air metering system between the J-spec NA's and the NA's in the USA.
Because i have seen people on supraforums.com stating that they run NA-T kits with only an SAFC (but at below 6psi) and much of the components that BROARDSIDE said he was getting.
Adi, That might be possible but 6psi is extremely low pressure. I just can't see the point of running such a big laggy turbo like the T4 and then run such low pressure. Decent boost (if you can call it that) wouldn't be reached until very high rpm and even then its over in no time! It still looks like a complete fudge of a turbo system IMO.
ok ok look perhaps i have not explained myself properly ill start againg
my supe at the mo is an n/a i have got the safcII installed just cos i got it cheap
(and it looks good) (sad i know)
i have got a boostlogic stage 2 kit coming :clap:
now this kit is complete and all the parts that i mentioned earlier are in it i have been told that i only have put the system on and it wont need no tuning initialy
after that i can then get the extras to start tuning
i have an the 75 shot of nitrous installed now but i wont be using it untill i have sorted and tuned the turbo and i am happy with the setup
i hope this is not to much wishfull thinking but the kit is suposed to be complete and 100% (so i have been told ) :shrug:
