Clutch Replacement
Samsar
Toyota part numbers so you can check prices, you may not need a new flywheel, it depends on condition of your current one.
13405-46040 Toyota Flywheel
31210-30262 Toyota Clutch Cover
31230-22100 Toyota Clutch Bearing
31250-30391 Toyota Clutch Disc
I'm looking to buy another one and just wondering if it's worth the aggravation ..
I don't understand, is your current clutch working okay? Do you mean you're considering fitting an aftermarket clutch?
The only reason to fit a new clutch would be if your current one is worn, the best clutch option - quietest, smoothest, easiest to use - for an NA would be a genuine Toyota one.
