J spec front pads
Scutch0
Green stuffs are probably the worse possible pads to fit, even EBC themselves don't recommend them for a Supra :D
Chris Wilson fast road pads will completely transform the braking performance of the smaller caliper setup. They're about £90 for a set of fronts.
i agree move away from ebc pads. i got a set of yellowstuff pads (only because they didnt cost me anything) and there no good.
i managed to cook them the other day, bellowing smoke they were, i was worried they where going to catch fire :blink:
Quick question, I've always found the brakes lacking feel and I've just had a quick look at the pads and it still seems the outer ones have loads of pad left the brake fluid level is low so I'm assuming the pad nearest the piston is completely worn, is this normal when the caliper seizes?
The rear pads were changed 2 months ago hence my suspicions being the fronts.
Sliders will be seized, a full car set of my fast road pads is £130 plus VAT, just fronts, which I don't recommend fitting, are £82 plus VAT. Sort the calipers first or it will just drink fuel, chew its way through another set of pads, and overheat them, as well as the discs. If you are on a really tight budget I will have some excellent, evenly worn used pads about the place. £20 an axle set for J-Spec ones.
