Swampy442 Posted February 3, 2011 Share Posted February 3, 2011 How do you measure it, is there a limit? My brothers Aristo has some odd things going on in the rear suspension department, I checked the bushes but the all have some play, the upper rear arms especially have alot of lateral play. So what is too much play? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted February 3, 2011 Share Posted February 3, 2011 When she gets pregnant? Sorry, erm, I don't know. Quote Link to comment Share on other sites More sharing options...
Animal Posted February 3, 2011 Share Posted February 3, 2011 I normally stop when my fingers start to desquamate Quote Link to comment Share on other sites More sharing options...
Robert Posted February 3, 2011 Share Posted February 3, 2011 LOOOL at the replies Quote Link to comment Share on other sites More sharing options...
gurteen0 Posted February 3, 2011 Share Posted February 3, 2011 :lol: Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 3, 2011 Author Share Posted February 3, 2011 So no serious replies then funny guys Theres enough experts on here, someone must have an idea... Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted February 3, 2011 Share Posted February 3, 2011 There should be no play at all. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 3, 2011 Author Share Posted February 3, 2011 So, in a rubber bush there shoud be no play at all? Id expect a bit because its rubber... Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 3, 2011 Share Posted February 3, 2011 Not sure there is a definative answer to that.. The only way to get an exact answer may be to get in touch with Toyota/Lexus and see if they will tell you from their technical data.. Depending on what sort of bush it is and where as to what i'd say is excessive or not. You should in theory not be able to pull on something and make it move but lever bar, maybe, yes. How much movement we talking about? An easier test is to compare it to the other side and see what that is like.. But whatever, i'd say no more than 2-3mm but that is a wild guess not knowing what arm/bush is on, if that makes sense. Quote Link to comment Share on other sites More sharing options...
Graham S Posted February 3, 2011 Share Posted February 3, 2011 I normally stop when my fingers start to desquamate Dare I google WTF that means!! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 3, 2011 Author Share Posted February 3, 2011 Not sure there is a definative answer to that.. The only way to get an exact answer may be to get in touch with Toyota/Lexus and see if they will tell you from their technical data.. Depending on what sort of bush it is and where as to what i'd say is excessive or not. You should in theory not be able to pull on something and make it move but lever bar, maybe, yes. Thats my problem, depends on the force you apply etc. They all look in reasonable condition, no splits etc and no play using your hands but something is definately up. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 3, 2011 Author Share Posted February 3, 2011 Dare I google WTF that means!! Desquamate, to shed or peel the outer layers of skin. Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted February 3, 2011 Share Posted February 3, 2011 How is it you're testing for play? If you've got the car jacked up and wiggle the wheel, none of the arms should move at all IMO, pretty sure you'd get an advisory or fail in your MOT if they did, I certainly have anyway. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 3, 2011 Author Share Posted February 3, 2011 Well I was using a pair of long nose pliers as I had no pry bar or anything to hand, but both top arms had a noticable amount of play Quote Link to comment Share on other sites More sharing options...
Animal Posted February 4, 2011 Share Posted February 4, 2011 Dare I google WTF that means!! Desquamate, to shed or peel the outer layers of skin. Yeah, like when you go all wrinkly after being in the bath too long. Quote Link to comment Share on other sites More sharing options...
movistar Posted February 4, 2011 Share Posted February 4, 2011 There shouldn't be any play at all, flex yes(unless you have uprated bushes like the neoprene one's), but no play. Remember the small amount of play you feel when checking for play will be massive in what you feel through the suspension when driving, especially if it affects camber, caster or toe. Quote Link to comment Share on other sites More sharing options...
dave finch Posted February 7, 2011 Share Posted February 7, 2011 if you got that much play id replace them or just poly bush the whole car will definatly make it handle better what ever you do Quote Link to comment Share on other sites More sharing options...
kill1308 Posted February 7, 2011 Share Posted February 7, 2011 if you got that much play id replace them or just poly bush the whole car will definatly make it handle better what ever you do I think quite a few people here have had problems with the Poly bush kits (I could be wrong though). If they need replacing I'd go with OEM parts. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted February 7, 2011 Share Posted February 7, 2011 One of my rear bushes needs replacing, and I'd prefer OEM parts, but do Toyota still sell them? Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 7, 2011 Share Posted February 7, 2011 For the main wishbones as far as im aware you can only buy the complete unit from Toyota, from what i've read the bush kits don't appear to last very long where as the o/e arms are good for over 100,000 miles, well my uk's were but ofcourse this could vary from car to car. The biggest downside is their not cheap, i have replaced all mine with new o/e and the car after a full geo at Centre Gravity drives very nicely, even on silly big 19's Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 7, 2011 Author Share Posted February 7, 2011 He cant afford/justify OEM arms, dont the upper rears chime in at 300 quid each or something? The cars only worth 400. But cheers for the (sensible) replies Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted February 7, 2011 Share Posted February 7, 2011 I think quite a few people here have had problems with the Poly bush kits (I could be wrong though). If they need replacing I'd go with OEM parts. I havent had any trouble with my R2 bushes they have been on the car for around 2 years now and still look new Not sure about the other brands though. If they do fail then i will just upgrade/replace them with new Ikeya formula arms Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 7, 2011 Author Share Posted February 7, 2011 If they do fail then i will just upgrade/replace them with new Ikeya formula arms Alright Brewsters millions! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 8, 2011 Share Posted February 8, 2011 If these are the same as MKIV Supra rear upper arms they are spherical bearings with rubber water seals, and should have NO play in them. If there is play then rear wheel steer and torque steer will be apparent, plus maybe some knocking noises. Quote Link to comment Share on other sites More sharing options...
