idle control valve question
Guest daz 6576
Guest daz 6576
hi there, cleaned my icv the other day and took it apart, the sensor has changed position when i was cleaning it so what im asking is, will it find its own position when put back on and driving again ???
im trying to get the idle speed down as its a bit high, tried to change settings on the throttle body aswell but i cant seem to get it down
cheers daz
so the idle is calculated by the ecu ??
im runnng an after market ecu also, so has the idle speed been done by the person who tuned it ??
Yes. Although most aftermarket ECUs aren't capable of using the stock idle control valve so you may well find it's controlling the idle by using fuel and timing adjustments alone. What ECU is it?
