Dale B Posted June 23, 2005 Share Posted June 23, 2005 Got the dreaded "click" on key turn this morning. Is the solenoid replaceable or do I have to buy a complete starter motor? Quote Link to comment Share on other sites More sharing options...
merckx Posted June 23, 2005 Share Posted June 23, 2005 You can also get the dreaded click if your battery is dead, do the electric windows go up and down okay? You shouldn't have to buy the whole starter motor, you can normally get them refurbished. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 23, 2005 Share Posted June 23, 2005 Try the battery first Dale, I've only heard of one starter motor going on a Supra before. Depends what sort of click it was! Gaz. Quote Link to comment Share on other sites More sharing options...
Aerotop Dave Posted June 23, 2005 Share Posted June 23, 2005 Talk to Chris Wilson. A new one is ~£260, Chris does a refurb for ~£60. Keep trying it though - mine was dodgy for about 6 months. Sometimes it would suddenly catch on the 14th or 15th turn! Quote Link to comment Share on other sites More sharing options...
Ian R Posted June 23, 2005 Share Posted June 23, 2005 Talk to Chris Wilson. A new one is ~£260, Chris does a refurb for ~£60. Keep trying it though - mine was dodgy for about 6 months. Sometimes it would suddenly catch on the 14th or 15th turn! Yep did mine never had a problem since Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 23, 2005 Share Posted June 23, 2005 If you want I can either refurb it if you fetch the car, or post the starter and I'll turn it around and post back next day. Quote Link to comment Share on other sites More sharing options...
Maxx Posted June 23, 2005 Share Posted June 23, 2005 Check the battery if its okay then do a refurb on the starter, if you do a search you'll find quite a bit on this. Refurbed mine about 12 months ago, the hardest part was getting the starter out of the car and back in again (this maybe due to having a UK TT Auto) there is very little room to work. I'd have Chris W do it if you don't want the hassle. If you decide to do it yourself you'll need BOTH the following parts from Toyota: Starter Kit #28226-74070 and Starter Kit #28226-22050 About £20 if I remember correctly. Be warned if it's a UK auto (not sure about manual) the starter bolts are a complete nightmare to get to. Goodluck Quote Link to comment Share on other sites More sharing options...
Lazarus Posted June 23, 2005 Share Posted June 23, 2005 Dale, if you've got the facilities, ie ability to get good access to the underside of the car at the front, I'd buy the solenoid repair parts from Toyota and do the job yourself. The parts are cheap and It shouldn't take more than a day (read that as a lazy day with plenty of tea breaks ). As said above, the only difficult bit is the access to the starter to remove/refit. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted June 23, 2005 Share Posted June 23, 2005 Battery. Quote Link to comment Share on other sites More sharing options...
Kopite Posted June 23, 2005 Share Posted June 23, 2005 i had that too Dale, was just the battery Quote Link to comment Share on other sites More sharing options...
Dale B Posted June 23, 2005 Author Share Posted June 23, 2005 It started ok after about 2-3 attempts. The battery seems ok, everything else electric works fine so my first thought was starter solenoid. Quote Link to comment Share on other sites More sharing options...
Maxx Posted June 23, 2005 Share Posted June 23, 2005 Thats exactly what mine did, it's definately worn contacts in the starter solenoid, be warned it took me and a buddy almost two hours to put the top bolt back on my UK TT Auto, I think you'll find this isn't the case with J-spec but I note your's is a UK right? He had to put the spanner on the nut for the engine bay and I had to turn it from under the car! If you need part number for the solenoid repair see my earlier reply for the bits you'll need. Quote Link to comment Share on other sites More sharing options...
QSC Posted June 23, 2005 Share Posted June 23, 2005 Sounds exactly like mine Dale - here's another one for Gaz's list, cause my starter solenoid was definitely faulty, and on a low mileage car too. I had a local auto-electrical place recondition it for £60. Been perfect ever since Quote Link to comment Share on other sites More sharing options...
Dale B Posted June 23, 2005 Author Share Posted June 23, 2005 Booked into Autoelectrics tomorrow £50 to refurb the solenoid ... bonus. Thanks for the offer Chris, this will be easier / closer Quote Link to comment Share on other sites More sharing options...
