Anyone got their engine out of their car?
Guest 2JZ Dan
Guest 2JZ Dan
Hi Guys
I'm toying with fitting a Viper V10 engine into my Supra (just happen to have one at work).
Just wondering happens to have an empty engine bay that I could measure or if someone could measure for me?
I basically want to make sure it will fit before I remove mine :)
Cheers
Dan :)
Hi Guys
Cheers
Dan :)
Sounds interesting mate! :thumbs:
Hope someone can measure up for you (maybe PM keron as he breaks these so might have one with no engine fitted at his place?) and there is enough room. A Viper V10 powered Supra would be quite something!! :eyebrows::cool:
Make sure you do a build thread if it will go mate as I'm sure lots of us on here would be interested!
Best of luck with it! :D
Guest 2JZ Dan
I have a empty bay I can measure for you :-) and any thing is possible with a little fab work my mate had one he was going to drop into a s13 and it fitted :-) ,
Was it Rich?
I put it into my S13 but changed plan.
I'll check the width :)
Any chance I could come t you and measure?
Dan :)
Guest 2JZ Dan
main measurements would be:-
Between the chassis rails
Between the Steering column and opposite chassis rail
Slam panel to bulkhead at gearbox height (top of box)
From front subframe to bonnet line
That would be a start :)
