Oddball87 Posted December 10, 2011 Author Share Posted December 10, 2011 Rear Diagonal tact in Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted December 10, 2011 Share Posted December 10, 2011 what time you there till tonight mate, got footy and wont be back to kerry untill. 6-7ish. if your up there till late ill pop on up mate. drop us a text. daz. Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 10, 2011 Author Share Posted December 10, 2011 fairly late mate will do Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 11, 2011 Author Share Posted December 11, 2011 We got the Front cross brace,Lower diagonals and Harness bar tact in looking abit more like a cage now still loads to go in. Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 11, 2011 Author Share Posted December 11, 2011 9" Grinder VS Magictorch Supra Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted December 11, 2011 Share Posted December 11, 2011 Ahh people are going to flip matt ha!! Cage was looking awesome, looking spot on Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 12, 2011 Share Posted December 12, 2011 Looking good. Must weigh a fair bit once finished? Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 12, 2011 Author Share Posted December 12, 2011 Looking good. Must weigh a fair bit once finished? Cheers dude not as much as you would think around 40 to 50kg if that. I hope I can still get the weight down to around 1300kg Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 12, 2011 Share Posted December 12, 2011 Its going to look crazy inside, well done so far mate and not as much weight as i thought in my mind. you keeping her white? Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 12, 2011 Author Share Posted December 12, 2011 Its going to look crazy inside, well done so far mate and not as much weight as i thought in my mind. you keeping her white? It will lol yes keeping it white I think i will paint Audi r8 white Quote Link to comment Share on other sites More sharing options...
neilthenut Posted December 12, 2011 Share Posted December 12, 2011 think mine weighed aboutn 60-70kg but that was all bigger tube- di yo save that front part i wanted of his car? Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 13, 2011 Author Share Posted December 13, 2011 think mine weighed aboutn 60-70kg but that was all bigger tube- di yo save that front part i wanted of his car? Yes mate call Jamie to let him no you want it before it goes Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 19, 2011 Author Share Posted December 19, 2011 Rear cross brace going in Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 19, 2011 Author Share Posted December 19, 2011 Also last night i started to put new under seal on. And i think i am going run the brake and clutch lines inside the car so it will clean up the engine bay even more. Quote Link to comment Share on other sites More sharing options...
hodge Posted December 19, 2011 Share Posted December 19, 2011 Also last night i started to put new under seal on. And i think i am going run the brake and clutch lines inside the car so it will clean up the engine bay even more. I've done this worker and clutch lines. It makes a massive difference in the engine bay look IMO. There's loads of room under the scuttle panel for them. Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 22, 2011 Author Share Posted December 22, 2011 I've done this worker and clutch lines. It makes a massive difference in the engine bay look IMO. There's loads of room under the scuttle panel for them. Did you use normal brake lines? i might use braided Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 27, 2011 Author Share Posted December 27, 2011 Rear cross brace in place. Looking more like a cage now Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 29, 2011 Author Share Posted December 29, 2011 (edited) Had a look over the engine i bought off magictorch. I took the sump off and had a quick look inside the crank has been knife edged, the cylinders have been re honed and has HKS pistons. Head has JUN Cam gears,HKS 264 cams and some port work done. oil pump, water pump, cam belt tensioner cam belt are as new. This engine will be a stop gap untill i build my other. Edited December 29, 2011 by Oddball87 (see edit history) Quote Link to comment Share on other sites More sharing options...
hodge Posted December 29, 2011 Share Posted December 29, 2011 Did you use normal brake lines? i might use braided Nope I used white braided lines. I made them up myself to the exact length I needed and had a local hydraulics company crimp them for me. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 29, 2011 Share Posted December 29, 2011 Nice work, that's a whole lot of bracing on the cage, in fact its more than mine and its MSA/FIA approved. Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 29, 2011 Author Share Posted December 29, 2011 Dash bar and driver side door bars in. The seat is just to see how much room we have its not staying Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 29, 2011 Author Share Posted December 29, 2011 Nope I used white braided lines. I made them up myself to the exact length I needed and had a local hydraulics company crimp them for me. cool thanks mate Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 29, 2011 Author Share Posted December 29, 2011 Nice work, that's a whole lot of bracing on the cage, in fact its more than mine and its MSA/FIA approved. Thanks lol yup there's a fair bit Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 29, 2011 Share Posted December 29, 2011 Looking good. Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted December 29, 2011 Author Share Posted December 29, 2011 Looking good. Quote Link to comment Share on other sites More sharing options...
