Offland's big single and weight reduction build
Oddball87
  • Replies 613
ha ha your having a laugh aint you??
Nope lol Thinking of removing all of it because it is put on quite thick, I reckon it would weigh quite i abit. I removed the sound deadening and that weighed i few kg, But ofcourse i will not drive around with no protection under the car i was thinking of just painting it with some Hammerite and then a few thin layers of waxoyl
I think i am going firm on this setup now
SRD stage 3 cams
Titan cam gears
Unorthodox pulley set
Ferrea valve train kit
Bronze guides
Shimless buckets
BC Pro rods
Mahle Pistons
Acl race bearings
Billet main caps
Arp main studs
Arp head studs
Billet tensioner bracket
New crank pulley
New water pump
New oil pump
New engine gasket set
Gate racing cam belt
Gates racing fan belt
Super spark coilpacks
I may change to Cosworth pistons and Carrillo h beam rods in the future if i go for more power and if i have the cash :)
Hi guys i am really stuck on what turbo to go for!! I have been looking at the GT42R-7275 that jamie put up on here i no its abit over kill for the power i want but i am a clown and will end up wanting more power in the furture :) I think its worth getting this now to save me money in the long run, instead of buying a smaller setup now runing it for a year say then spending loads to change for a bigger turbo what you think? Also will this turbo fit on a HKS GT Manifold? thanks
  • 2 weeks later...
If you're going to loose all that weight I would look seriouly at going too big of a turbo. My 67 Billet is absoluetly mental and I'm running 1335kg at the mo, when it goes down to sub 1300kg it's going to be even worse. I'm running 720bhp, and with a couple more small tweaks (for example a small boost increase - I run a conservative 1.5 BAR compared to most of the big hitters on here) I'm sure a 750bhp is do-able. That would put my power to weight on par with a 900bhp UK Spec.
I personally would go for the smaller turbo, then yes sell it and swap for a larger one later for a small loss
Edited by jevansio (see edit history)
I just bought a BW S372 as a stop gap till my 7675 turbo is back from AET, i didnt want to hold my build up waiting for my turbo, huge looking thing but only 72mm, be interesting to see what it will do as they are pretty cheap.
