Glass Headlights- Electronic Beam Adjustment
Guest Topgear
I don't suppose you fancy doing it and writing a guide for the rest of us? ;)
I would, no bother, in fact I probably will. Trouble is I'm in the middle of my single install so getting the car up and running is no.1 priority at the moment. Making the headlights dip with a switch is going to be at the back of the queue for a little while.
It's easy to wire them up, the sockets on the lights have a red+and a black- , connect these to aux power feed (or light power feed circuit) and then use a negative switched supply to either of the 4 other pins on the headlamps (can't remember the other colors) but they logically go from low to high light level , I'm going to wire mine to a headlight level switch from a mk3 supra (has same switch shape and size) a the mk4 switch but a different style, until I manage to get the correct mk4 switch
Red+
black-
negative feed run to any of the other 4 pins (same pin/Color each headlamp) to hue desired level adjustment
