ronttuk Posted January 31, 2011 Share Posted January 31, 2011 I aquired an air box to replace the HKS system on my UK spec but the clips are broken has anyone managed a successful repair of an air-box with broken clips I have a few ideas but wondered if anyone has done a better job. pics if possible please. Quote Link to comment Share on other sites More sharing options...
ronttuk Posted January 31, 2011 Author Share Posted January 31, 2011 Am Guessing it cant be fixed ?? Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 31, 2011 Share Posted January 31, 2011 Exactly which bit is broken on yours ? post pics if you can Quote Link to comment Share on other sites More sharing options...
ronttuk Posted January 31, 2011 Author Share Posted January 31, 2011 ill try http://i485.photobucket.com/albums/rr219/ronttuk63/airbox002.jpg Quote Link to comment Share on other sites More sharing options...
ronttuk Posted January 31, 2011 Author Share Posted January 31, 2011 Well the 1st pic worked Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 31, 2011 Share Posted January 31, 2011 Theres not much left to work with by the look of it, heres a pic of mine if it helps at all Quote Link to comment Share on other sites More sharing options...
ronttuk Posted January 31, 2011 Author Share Posted January 31, 2011 Thats how it should look lol has anyone repair one ?? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted January 31, 2011 Share Posted January 31, 2011 Mine are both broke. Still enough to keep it closed and be able to open. I'd just get a new one can't be much 2nd hand from a breakers. Even new might not cost much Quote Link to comment Share on other sites More sharing options...
evinX Posted February 1, 2011 Share Posted February 1, 2011 Ive repaired a damaged headlight where the clip bits broke of, go down to halfords, get some mesh for £2, get the solder iron out, shape the mesh all around the clip and unit, do the top first then the bottom, use the iron to sink the mesh into both sides of the plastic, rejoining them...then get a takeaway tub, break it up, light the plastic up and let the plastic drip over the mesh, itll go black, ones thats dry and done you sould be able to pick the whole unit up by the broken clip without it breaking:) Quote Link to comment Share on other sites More sharing options...
Ark Posted February 1, 2011 Share Posted February 1, 2011 They all snap like that. Assuming you still have the bit that broke off you could drill a couple of very small holes for wire pins (gives the strength) then just glue the part back on. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 1, 2011 Share Posted February 1, 2011 Ive repaired a damaged headlight where the clip bits broke of, go down to halfords, get some mesh for £2, get the solder iron out, shape the mesh all around the clip and unit, do the top first then the bottom, use the iron to sink the mesh into both sides of the plastic, rejoining them...then get a takeaway tub, break it up, light the plastic up and let the plastic drip over the mesh, itll go black, ones thats dry and done you sould be able to pick the whole unit up by the broken clip without it breaking:) Do you watch Blue Peter ? Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 1, 2011 Share Posted February 1, 2011 They all snap like that. Assuming you still have the bit that broke off you could drill a couple of very small holes for wire pins (gives the strength) then just glue the part back on. Mine haven't Quote Link to comment Share on other sites More sharing options...
ronttuk Posted February 1, 2011 Author Share Posted February 1, 2011 I bought it as it is no clips or anything to re use Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 1, 2011 Share Posted February 1, 2011 I drill through both flanges and use a tie wrap which gets cut and renewed when the filter is changed. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 1, 2011 Share Posted February 1, 2011 Or a self tapping screw if the flange is thick enough Quote Link to comment Share on other sites More sharing options...
Paul Posted February 1, 2011 Share Posted February 1, 2011 Or a nice red bow Quote Link to comment Share on other sites More sharing options...
