Air noise and induction kits
Hi all,
How loud should the air suction noise be with an induction kit fitted? I have a foam pod filter on, and the noise under acceleration or boost is actually louder than, or at least equally as loud as the engine.
Is this normal? i have had suspicions since i bought the car that i may have a boost leak somewhere.
TIA
adi
It's pretty loud.  If you had a boost leak, you would know about it :)  The slightest of holes causes huge drops in boost pressure.
I consider the swoosh of air to be part of the engine noise.  If you want the engine bit louder, get a decat special to go!
-Ian
