barneybrendan Posted January 31, 2011 Share Posted January 31, 2011 for anybody that has their battery in the boot,how have you secured it.seen the battery boxes but the plastic seems really flimsy. Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 31, 2011 Share Posted January 31, 2011 Metal box, either bolted through or welded (and yes I made VERY sure the terminals were kept clear) Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 31, 2011 Author Share Posted January 31, 2011 Metal box, either bolted through or welded (and yes I made VERY sure the terminals were kept clear) was thinking about that , Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted January 31, 2011 Share Posted January 31, 2011 mines in the boot but gonna relocate it soon as ive riveted it to the top of the centre beam might move it some place more secure Quote Link to comment Share on other sites More sharing options...
hodge Posted January 31, 2011 Share Posted January 31, 2011 If you still have your rear seats in. A optima battery fits perfectly in where the stock sub was behind the seat and when you close the seat back up it locks it in place. No way that will ever going to move anywhere. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 31, 2011 Author Share Posted January 31, 2011 If you still have your rear seats in. A optima battery fits perfectly in where the stock sub was behind the seat and when you close the seat back up it locks it in place. No way that will ever going to move anywhere. is that what you have done.I need a new battery anyway and was thinking of an optima battery.Have you got any pics mate. Quote Link to comment Share on other sites More sharing options...
johnny g Posted January 31, 2011 Share Posted January 31, 2011 is that what you have done.I need a new battery anyway and was thinking of an optima battery.Have you got any pics mate. I can't believe you're asking that to Hodge of all people! Quote Link to comment Share on other sites More sharing options...
hodge Posted January 31, 2011 Share Posted January 31, 2011 I'll dig 1 out for you bud. Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted January 31, 2011 Share Posted January 31, 2011 i have a red top optima in a billet alloy cage will the cage fit too hodge Quote Link to comment Share on other sites More sharing options...
hodge Posted January 31, 2011 Share Posted January 31, 2011 Here's my blue supra And my current supra. This has no rear seats but an install in it's place. Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 31, 2011 Share Posted January 31, 2011 Are there any top straps holding the batteries in??? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 31, 2011 Author Share Posted January 31, 2011 cheers. Quote Link to comment Share on other sites More sharing options...
hodge Posted January 31, 2011 Share Posted January 31, 2011 Are there any top straps holding the batteries in??? Nope there jammed in by the seat there's no way they'll come out or even move. Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 31, 2011 Share Posted January 31, 2011 Nope there jammed in by the seat there's no way they'll come out or even move. err.... if something goes wrong and the car goes upside down, there is EVERY possibility that will come out and hit someone... (but just my 2c) Quote Link to comment Share on other sites More sharing options...
hodge Posted January 31, 2011 Share Posted January 31, 2011 Because the taper on the seat there's no way they'll come out. The seat tapers towards the battery so the gap gets smaller the higher you go up the seat. If you know what I mean. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 31, 2011 Share Posted January 31, 2011 Billet aluminium cage for me, granted it isn't in the rear but it could easily be located there. Couple of bolts to hold it in place or welded as Gav suggests. Least you won't get any shorts that way With regards to the battery relocation, how do you guys do it? Do you just run a cable from the fusebox attachment all the way to the boot? I can't remember, is there a seperate one for the alternator? Same with the earth or do you create a new one under the seats or something? Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted January 31, 2011 Share Posted January 31, 2011 thats what ive done scott it seems to be working so far Quote Link to comment Share on other sites More sharing options...
Scott Posted January 31, 2011 Share Posted January 31, 2011 thats what ive done scott it seems to be working so far What wires did you run to the boot? All 3? Just the 2 positives? Just the one with 2 positives joined in the bay? What did you earth onto? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 31, 2011 Author Share Posted January 31, 2011 (edited) good idea but i think id just add a nice fancy ratchet strap over the top.I take it you just cut away or removed the faom section.at the moment i have had to fit my battery on the drivers side front so i have just one wire running across to it from the isolator i fitted.After a bit of reading it seems just one live feed running back to the battery and the earth to the body Edited January 31, 2011 by barneybrendan (see edit history) Quote Link to comment Share on other sites More sharing options...
hodge Posted January 31, 2011 Share Posted January 31, 2011 Get a fused block with 2 x 4 Gauge and 1 x 0 gauge. Put the 2 positive wires in the 4 gauge ports and run a 0 gauge wire to the boot. Earth the battery with a 0 gauge earthing strap to the chassis. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 31, 2011 Share Posted January 31, 2011 Get a fused block with 2 x 4 Gauge and 1 x 0 gauge. Put the 2 positive wires in the 4 gauge ports and run a 0 gauge wire to the boot. Earth the battery with a 0 gauge earthing strap to the chassis. Would work out an expensive job that. The 0 gauge is ridiculously priced. Where did you mount the earthing strap John? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 31, 2011 Author Share Posted January 31, 2011 Does it have to be that gauge even if its just for the battery for normal use. Quote Link to comment Share on other sites More sharing options...
