SRD - Ridox Single Turbo Project Build
Geo
So the Car is with LeeP SRD (Supra Racing Developments) just now, and we have decided to go for a nice 650bhp car, i didnt want a car that was undriveable with loads of power, still enough power to keep 98% of cars at bay. So iv Spec'd up the car as it is just now, and will be adding the parts i buy and Lee installs at the Bottom. Lee will add pics when he gets round to it. :D
The Car
Engine Specifications:
Toyota Stock Straight 6 Engine
NGK Plugs BKR8EIX
HKS 256/264 Cams
Greddy Plenum
Q45 Throttle Body
Bosch 044 Fuel Pump
Larger Lexus Oil Filter
SRD FMIC
Whifbitz Bonnet dampners
Exhaust Manifold Gasket
Inlet and Exhaust Cam Cover Gaskets
Turbocharger & Induction:
Precision T6765 .68(67mm turbo with .68 ar)
50mm Turbosmart Waistgate
Whifbitz Tubular Manifold
Whifbitz 3'' Mid/Down pipe
Turbosmart Raceport BOV
Unorthadox Racing Pulleys
Toyota OEM Engine Gasket Set
Toyota OEM water pump
Toyota OEM timing belt idler wheel
Toyota OEM timing belt tensioner
Toyota OEM crank shaft pulley
Toyota OEM exhaust manifold nuts x12
Toyota OEM Timing Belt
Whifbitz Adjustable Cam Gears
Fuel Lab 535 FPR
SRD Billet Water Inlet Pipe
TRD Thermostat
SRD Heat shield
Water output pipe Smoothed off and Polished
4'' Polished Intake Pipe
4'' K&N Filter
Whifbitz Breather Tank
Braided Oil Feed and Return Lines
50mm BOV
Fuel, Tuning & ECU:
Syvecs ECU with Trac Control
3.5 Bar AEM Map Sensor
Power Enterprise 800cc Injectors
Injector seals
Stock Fuel Rail
Stock Fuel Filter
AEM wideband
Fuel Pulsation Dampner
1/8 NPT straight fitting
Cooling:
SRD 4'' FMIC with Custom Piping
Koyo Radiator
Supra FMIC and Rad Cooling plate
AAP Motorsports Dual Fan Kit with Shroud
Heat Wrapped Down/Mid Pipe
HKS Oil Cooler
Blitz 1.4bar Rad Cap
Power Steering Cooler
Exhaust:
Supra Dragger 4'' Exhaust
Envy Decats
Drivetrain:
6 Speed Manual Getrag Gearbox
Whifbitz Solid Gearshift Bushes
Toyota Gear Selector Seal
Stock LSD
Whifbitz Solid Selector Bushes
Southbend DXD-F Series Clutch
clutch cover washer
Suspension, Wheels, Tires & Brakes:
UK Spec Brakes all Round 4/2 Pot(Front and Rear)
OEM Disks, Chris Wilson Fast Road Pads
Do Luck Braided Brake Lines
Wed SA-70 Wheels 9x18 and 10x18 +32 offset
Race Wheel Nuts
Falken 452 Tyres all Round
Tein Coilovers and Adjustable Suspension
Cusco Front and Rear Strut Braces
Interior & ICE:
JVC KW-AVX740
Alpine front and rear speakers
Defi Control Unit, Water Temp, Boost, Oil Temp
DC2 Recaro Bucket Seats, with MO BRIDE rails
Carbon Fiber Gauge Holder
Exterior:
Full Genuine Ridox Body Kit.
UK Bonnet Scoop
De Wipered
De Ariel
UK Glass Headlights
6000k Knight Racer HID's
Performance:
Max power - 712 bhp
Max torque - 659 ftlbs
Fly - 605rwp
Edited by Geo (see edit history)
  • Replies 343
Posted Images
Have you brought the RLTC Mate?
If not dont bother and use the money from the RLTC aswell as selling the aem, and dli and just get a syvecs fitted mate which has traction control built in plus all the other major selling points which are all over this forum.
Ryan
Ryan
Its with Lee just now bud, so id have the RLTC, AEM, DLI. Pm a price for the Syvecs along with it mapped bud. Wont be picking her up till next year at some point so im not sure which route i'll go with regarding the ECU, all depends on cash.
  • 1 month later...
Lee just sent me a text. He did a compression test
Results
1:198
2:197
3:198
4:199
5:197
6:198
So we can say the Engine is in good condition with good numbers all round :D
pic of Bay Below before Lee Starts
Right,
So iv decided to go with the syvecs ECU now, Ryan is sorting that out for me. So Lee is ripping the AEM ECU, HKS DLI out. Ryan said to keep the AEM 3.5 Bar sensor as it will work perfectly fine. So the AEM and DLI is up for grabs.
Spoke with Lee today, and were now relocating stuff about a bit to tidy up the Gauges in the car, and the Engine bay. The Defi Controller will be in the Stock drawer below the Stereo, and were moving the boost gauge from the Air Vent to the Carbon fibre holder.
trying to figure out what else i need to do when its with Lee, any help will be appreciated
cheers
  • 2 weeks later...
Bay Partially Stripped, turbo side still to come off.
Stock Cams Removed
HKS 256/264 Cams to be Installed
Some Surface Rust, Lee polished them up
Runners Stripped down and parts removed thats not needed
All Cleaned up and ready to go back on
HKS cams installed and clearances checked all ok. :D
New Front Main Seal installed
  • 2 weeks later...
Little Update -
Iv SORN'd the car today as no point wasting tax, plus it needs and MOT also.
Also just off the phone to Paul, and ordered up Fuel Lab fpr with gauge and fitting kit, and a Turbosmart Race port Bov.
All i need now is rear tyres, and some new plugs. :D
Little Update -
I've got NGK's on special offer at the moment mate....
Whifbitz Pulleys Installed with Polished Nuts
Turbo Housing Polished, with an Elbow Welded on, so the Intercooler Piping Runs Under the Chassis Leg
Cam Covers Polished with -12 Fitting Welded On
Catch Can with -12 Fitting Welded On
Engine as it stands :D
Superb work on the cam covers, that -12 conversion looks OEM.
it does look rather nice eh. :D
The blending on the cam covers look very good indeed. As Jamie sais looks OEM.
Lee has done another great job
Great work, what are you doing with the whole in the wing? The hks I/c route looks much tidier IMO!
Leaving it all upto Lee bud, iv got a few idea's but im sure Lee will have better ones. :D
Really coming together now mate...the polishing work looks great! Cant wait to see this in the flesh when its all done!
Yeah cant wait bud, few things still to buy etc, but be worth the wait TBH.
Drift Bear, has bought my old walbro and Lee is sending me it up, Alex is coming down to pick it up, so if you fancy popping over for an hour then be good to see a couple of nice cars :D
Does lee do all the welding and blending himself Geo.
That i dont know bud, id need to ask him TBH.
When are you due to get the car back mate?
No idea mate, iv aked Lee if need be can the car be kept a while longer, due to me being so far away i want it 100% as its a long ass AA drive back down of anything goes wrong.
Im guessing April/May time, i know Jamie's car is being done before mine, but Lee with float between the two of them.
Been round at Lee's today had a quick looksy at you motor.
It's coming along nicely everything polished up.
Can't say I'm feeling the Whifbitz cam pulleys, there are much easier on the eye versions out there. I'm sure they will do the job though.
thats no fair being so close, i can only wait for pic updates when lee fires them over :D
The way im going with the bay though the pulleys will match everything. :D
This topic is now closed to further replies.
