Johnny's HKS Twin Build thread
hodge
  michel lane said:
Did you seal the fan stroud on the rad ? if you noticed the fitment for the mvp units are not that good ,what i did was put some door seals around the fan stroud and then positioned the unit on the rad, this fully seals the air flow. I replaced my fans with spal units as they gave up early last year .I am averaging 79degrees on idle according to the aem unit. Have you checked to make sure both fans are coming on ?
Yeah mate I got the fans flat against the rad after s few hours messing around and with a little help from the grinder.
Both fans are working fine. On idle the car is 88.6 degrees according to the syvecs.
  • Replies 664
Posted Images
  Chris Wilson said:
Post a log from the Syvecs showing RPM, water temp, fan switching and MAP if you like. It may show what conditions the overheat occurs, I am not sure if you can add all these to one screen, I have only had a brief fiddle with their logging stuff.
Chris I'm a total computer retard I wouldn't know where to start and I'm sure the s6 only has a very brief data logging facility.
It has from all the Ecu's I know in it's price range the best!
You can display up to 30 parameters on one screen but can setup up to 6 screens on one worksheet. Go out to car and connect cat5 cable to Ecu. Open up sdata... Then press device then read data... Type in download comments if you wish and press then OK. Select yes to delete data on Ecu after it's pulled on both prompts. Then press File.... Load latest log in sview.
On the right hand side you will have all parameters logged. Select ect1, map1, rpm, tps1
Done
One of the most useful tools you can have is a spot temp laser gun ; its not fool proof but helps greatly without removing anything .
point the gun at various places -bottom of rad, top of rad , after stat ,pump etc- it will show you whats happening temp wise - if you had a second car you can compare the numbers.
It would show any blockages across rad for example
They are cheap now (made in china ) £40 , but a great addition to your tool box
Will it have logged all the time the engine was running Ryan? As you know, I too am a computer illiterate, but now I have the ability to log my own stuff I am a total convert. It's just made for after the event crisis analysis. Pity Jurgen hasn't got logging from his failure. Maybe he has though, :idea: he mentioned some sort of Access Port or whatever..... Hmmm.
Aye - Hodge has done the water pump and the thermostat. Now, he took it out, with his son watching the water temperature on the laptop (Syvecs Software). The water temp went to 96 degrees - so he backed off. That was to 4500rpm. The stock gauge never moved, though.
Any thoughts?
  hodge said:
Yeah it seems to be pressurizing jamie. its makes the top water pipe solid once the engine it turned off. Things are pointing more towards the head gasket.
You can log it mate, Ryan hooked up a sensor to my top water neck to check to see if mine was ok at full boost on the dyno.
Only time i had a problem with pressurising water was when my block cracked on the old engine.
I've tried 1 Lee, I'm not sure as chris wilson said I'm getting a false reading due to the chemicals in the coolant. My sniff test kit said it should turn yellow if exhaust gasses are present and it goes dark green (from its original blue colour).
  Lee P said:
If it's changing colour it's normally a problem. It shouldn't change at all.
Did you get the head skimmed when you had it off?
Nope, it was a refurbed head that I bought from Dude. Cleaned, new dual valve springs, etc
Ah ok, would have needed to be checked for straightness, they usually bow in the middle a bit and need a skim. Also pressure test it for cracks, that was probably already done though if it was refurbed.
Edited by Lee P (see edit history)
  hodge said:
Johnny it's maybe worth checking with dude to see it it was skimmed and had been checked for cracks but I'm sure it will have.
I've just PM'd Dude now to ask him - and to see if he can help at all with this. He was great with the head, so I'd be very surprised if the head itself was the issue.
I doubt it will be as John really knows his stuff, but it's worth asking the question mate just to rule it out atleat.
That was the head that was on Mark R's car when it crashed, it was running fine and the bottom end was mint, no signs of anything wrond and he had the head checked to see if it needed facing.
AFR now fit a bleed screw on the the heater pipes at the rear.
Any thoughts?
As Jamie says, are you sure there *IS* a problem at all and it's not the Syvecs set up with the wrong calibration table for the sender you are using? Does it actually boil if you let it keep running? If the stock gauge isn't moving.....
