Guest Andy Bird Posted January 31, 2011 Share Posted January 31, 2011 Hello all ive had her for a day and got some issues that need sorting can you help the dash lights on the dials has gone. Its got the trd dials with e glo background they flickered yesterday and just went out this morning? Maybe just a fuse? Any other common reason? How hard is it to get the dash off as i want to replace all the blown bulbs behind the heating etc. The rocker cover gasket is leaking i have tightened the bolts up as they were alittle loose but cant get to the one on the back which it seems the oil is coming from. Do you have to take off the inlet manifold to get into the plugs? As if i remove the plug cover i can tighten up the back bolt and i want to replace the gasket thanks all Quote Link to comment Share on other sites More sharing options...
dwayne Posted January 31, 2011 Share Posted January 31, 2011 you could use hecklers guide to removing dash panels http://www.internetwork.org.uk/kit_inst/dashrem.htm i dont have any experience with the other problem as i havent tackled it myself Quote Link to comment Share on other sites More sharing options...
Guest Andy Bird Posted January 31, 2011 Share Posted January 31, 2011 Seems fairly easy ill give that a go tomorrow Quote Link to comment Share on other sites More sharing options...
AndyT Posted January 31, 2011 Share Posted January 31, 2011 Seems fairly easy ill give that a go tomorrow Think Heckler got my dash out in about 10 mins. Just don't force anything it really does clip out easily. Quote Link to comment Share on other sites More sharing options...
