Ibrar Jabbar Posted February 1, 2011 Share Posted February 1, 2011 Great project, subscribed Quote Link to comment Share on other sites More sharing options...
fuldhat Posted February 1, 2011 Share Posted February 1, 2011 Looking forward to some good video.. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted February 1, 2011 Share Posted February 1, 2011 In a nut shell get a pre 1993 soarer engine and your laughing. Thats what I've got I'm going down the single turbo route (copy gt35r) though with a Haltech E6X. Quote Link to comment Share on other sites More sharing options...
James Posted February 1, 2011 Share Posted February 1, 2011 Cool project! Hope the results are as desired! Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted February 2, 2011 Author Share Posted February 2, 2011 Thats what I've got I'm going down the single turbo route (copy gt35r) though with a Haltech E6X. Nice one. You will have fun running an E6x with this engine! I wont touch them anymore Quote Link to comment Share on other sites More sharing options...
Batmax Posted February 2, 2011 Share Posted February 2, 2011 Subscribed Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted February 2, 2011 Share Posted February 2, 2011 Nice one. You will have fun running an E6x with this engine! I wont touch them anymore Oh dear, what problems did you run into? I've been sent a base map, wiring diagram etc from haltech. It fired up on the stand, but wasnt great to say the least. Edit: Will give you a call later, dont want to clutter up your thread! Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted February 13, 2011 Author Share Posted February 13, 2011 Just a quick update as had no time on it at all recently All turbo fab is done just need to wrap it all now and coat. Whole of Sump has been removed for welding on some Jic fittings for oil return. Just waiting on some ARP head studs and a gasket set to arrive. Now moved onto the engine stand to strip and check over. Had to make up some custom bolts to mount on the engine stand. Decided im going to take out the cores of the turbo to run up as a N/A first to make sure no stray bits of weld go through these rare turbos and also will allow me to 4D map as will map the engine as an N/A based on TPS and RPM and then add another axis to the table for manifold pressure when i add the turbos. Made up a new loom for the engine also which makes it plug and play for the supra install Ryan Quote Link to comment Share on other sites More sharing options...
mikeyh Posted February 13, 2011 Share Posted February 13, 2011 looking good ryan should be a great conversion:) Quote Link to comment Share on other sites More sharing options...
Nic Posted February 13, 2011 Share Posted February 13, 2011 Decided im going to take out the cores of the turbo to run up as a N/A first to make sure no stray bits of weld go through these rare turbos Are the turbos off, Porsche? Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted February 13, 2011 Share Posted February 13, 2011 *gently stokes the engine* wow :-) that is going to be one nice car!! Quote Link to comment Share on other sites More sharing options...
bignum Posted February 13, 2011 Share Posted February 13, 2011 Good work ryan:cool: Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted February 13, 2011 Share Posted February 13, 2011 good stuff ryan; watching this with interest Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted February 18, 2011 Author Share Posted February 18, 2011 Done a few more bits on the engine, Ordered all new bearings, seals, belts and stripped down the engine to give it a once over and fit some MLS Headgaskets which are 0.2 mm thicker to help lower the CR down to 9.75:1 Off down to AFR tuesday to map a car and get Matt to clean and flow test the 7MGTE Injectors ...then its back home to fit all the ARP Bolts and get the engine complete again hopefully on sunday. Fitted a Bosch 044 to the car also and my old bilsteins from the white car. All turbo kit wrapped Just awaiting flywheel and then it all goes in the car Ryan Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 18, 2011 Share Posted February 18, 2011 you dont hang around mate, nice update. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted March 2, 2011 Author Share Posted March 2, 2011 Engine is fully overhalued and now back in the car but sadly my SLR finally died it death late last night Here are some pics from SLR when it worked and iphone of both engine and gearbox overhaul. Will get a decent camera soon when funds allow Have taken the cores out of the turbos to run as an n/a first to get a 4d map on it. Just made some blanking plates Fitted bigger injectors and coil on plug ignition also Quote Link to comment Share on other sites More sharing options...
Homer Posted March 2, 2011 Share Posted March 2, 2011 Moved to projects section Very interesting project Ryan, looking forward to the updates This is probably a pretty dumb question, but are you expecting any heat related issues with the turbo's location? I'm thinking of the issues Eric had with his conversion.. What are you doing different to reduce the under bonnet temps? Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted March 2, 2011 Share Posted March 2, 2011 What did you use for COP? Did some of the later uz's (4.3,4.7) have cop? Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted March 3, 2011 Author Share Posted March 3, 2011 Moved to projects section Very interesting project Ryan, looking forward to the updates This is probably a pretty dumb question, but are you expecting any heat related issues with the turbo's location? I'm thinking of the issues Eric had with his conversion.. What are you doing different to reduce the under bonnet temps? My turbos are a fair bit smaller than erics so i think i might be ok but im going to keep an eye on the temps on the dyno with a thermocoupler under the bonnet and make some heat shields up for the hot sides of the turbo. Dont want to put a blanket on the turbos tho as the Vains turbos dont like this!!! But will be running as an N/A first to map then add the turbo cores afterwards. Got this weekend to work on it and hopefully when i get back from working in spain on the 15th it will be late nights ahead to get it running. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted March 3, 2011 Author Share Posted March 3, 2011 What did you use for COP? Did some of the later uz's (4.3,4.7) have cop? I have used the 2uz coils but any from a 2zzfe celica engine will work fine. Not 1zzfe as they are too short Ryan Quote Link to comment Share on other sites More sharing options...
hodge Posted March 3, 2011 Share Posted March 3, 2011 Got this weekend to work on it and hopefully when i get back from working in spain on the 15th it will be late nights ahead to get it running. Don't do what I did n work on it the day of your anniversary. I got tortured about the other Sunday we got it started. She's only just started talking to me that last few days lol. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted March 16, 2011 Author Share Posted March 16, 2011 Custom 1uzfe to v160 Billet Flywheel arrived Truely a work of art and can get them made for about £360 delivered Quote Link to comment Share on other sites More sharing options...
Geo Posted March 16, 2011 Share Posted March 16, 2011 Shiney Who did the custom work for that bud? Quote Link to comment Share on other sites More sharing options...
Wez Posted March 16, 2011 Share Posted March 16, 2011 Very nice matey Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 17, 2011 Share Posted March 17, 2011 Nice progress mate Quote Link to comment Share on other sites More sharing options...
