ripped_fear Posted January 29, 2011 Share Posted January 29, 2011 Right so I will try my best to describe this as best as I can. basically I want to install a set of 3 point harnesses to my seat in the supra. I have electric, leather, non facelift front seats, and really want to mount them to these rather than have buckets. Similar to the set up on the fnf supra... (waiting for the abuse ) would it be legal/safe to feed the strap at the back between the head rest, and the back of the seat rather than putting a whole in to the seats them selves, and then mount the rear of the harness to the car like this? if so where would be the best place to mount the fixings to the car? any ideas? Thanks... Quote Link to comment Share on other sites More sharing options...
Graham S Posted January 29, 2011 Share Posted January 29, 2011 I think the best way to mount harnesses is at an angle no more than 10 degrees. So in theory there is no other way than to either have a roll cage or to have a rear strut bar.. If I remember correct then they are fine for going through the headrest part. I'm sure mine had them when I first saw the car! Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 29, 2011 Author Share Posted January 29, 2011 ok mate chears! thanks for the help Quote Link to comment Share on other sites More sharing options...
Graham S Posted January 29, 2011 Share Posted January 29, 2011 The 10 degree thing is BDC spec, but in all honesty its what you feel comfortable with in the event of a serious accident, rather than the whole look/feel of harnesses. I don't think you'd get any rear passengers in the car no matter where you bolt them dude. Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 29, 2011 Share Posted January 29, 2011 Not sure what you're trying to do for your description, but harnesses NEED to pass over a harness bar or cage after the seat to maintain the correct angle and prevent you crushing your spine in a crash. When you fit harnesses you need to be aware of the impact, IMHO I would not run harnesses now without a cage, and you need to consider the potential for dmamaging your neck in a crash (hence the use of hans type devices and the use of a helmet). It really is a do it all or nothing situation as far as I'm concerned, and since I don't want to drive around with a crash helmet on I'll take my chances in the car as toyota designed it, ie OEM seatbelts Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 29, 2011 Author Share Posted January 29, 2011 in that case mate ill stick to what I have, chears for the advice but i dont want to start doing roll cages and evrything just yet money is going elsewhere first! thanks for the advice. Quote Link to comment Share on other sites More sharing options...
