Amuse ecu help!
dcarrter21
It feels like its running the turbos in Parallel, the rev limit is around 7.5k now.
It won't be the ECU causing the turbos to run in parallel, but it could have been converted to run that way. What rpms do you get positive boost? It should be around 1.8K rpm if running sequentially or 3K+ rpm if running in parallel.
think the boost is running a bit high, mine does that too,
feels fast tho lol
im getting an AFR gauge next, as i dont want the engine running lean, and scared that high boost will be lean
PS where did you get the ECU from?
