Loosing coolant
gavin.starr
How do folks, Im loosing coolant at the moment around 1 litre every week and a half :blink: i have to carry water in the car for when i have to top it up.
I changed my matrix around 2 years ago for a re furbed one so i dont think its that but im not ruling it out. Im thinking its the rad cap no particular reason i just have a sneeky suspition, i cant seem to find any leaks on any of the pipes, i have been looking for ages and cant find it.
Is there any notorious places for cooland pipes leaking that are hidden out of sight i need to take a look at.
Gav
I wouldn't have thought that it would fail after such a short time, but depending what one you got I suppose its possible. Is it a cheap one or second hand if so just buy a new one, I had the same problem and as heckler has said, and I just bought a nice blitz one or sumopower on ebay and job done.
I had the same problem when i had my engine rebuild, losing lots of coolant, turned out Michel had put the wrong rad cap on mine, a blitz one for a mkiv, turns out the koyo rads need a different cap, deeper like you said, a mk3 one works just fine. Few quid from halfrauds.
Rad cap first, as it's the cheapest option. The other places I've found on the supe to leak is the plastic top of the stock radiator cracks with age, and it only leaks when the car is fully warmed up. The other things are the back of the water pump, but this is usually obvious, and finally, I've read threads about NA core plugs falling out. Though again this is doubtful.
I think I have found the problem, it over heated on me the other night, so up comes the bonnet and I could hear a slight hissing noise, turns out I have a small hole in the radiator.
Im in preston so would any one know of a rad specialist that could pressure test it for me and weld up the hole if possible
Gav
