Blumin Muggy
how_supra
We have no air con, our windows barely open and its flippin muggy.
alert alert office meltdown................. :Pling: :Pling: :Pling:
Don't get me wrong, I love the summer, but heat exhaustion pending...........can't be arsed to work..............la la la la la..............need beer..........................mmmmmmmmmmmmm ice cream
:thanks:
We have the air con on the doors open to the Industrial Freezer next door!!!!!!! blast of air at -18 great for cooling down. :D
To hot to work so we have been seeing how far you can send a wheat crunchie with a plastic light saber!!! :p
Guest The Flash
We've had aircon recently installed :thumbs: .... but have not yet got the Planning Permission to put the condensers outside the building :shrug: So we can look at the system while roasting our nuts off!
Aren't there guidelines for working conditions? I'm pretty sure that employers have to supply heating if the workplace is to cold - thought it might be a similar story if it's too hot.
Get a fan on your desk or where you work, it'll be the same air but it still cools you down.
What is the maximum/minimum temperature in the workplace?
The Workplace (Health, Safety and Welfare) Regulations 1992 lay down particular requirements for most aspects of the working environment. Regulation 7 of these deals specifically with the temperature in indoor workplaces and states that:
(1) During Working hours, the temperature in all workplaces inside buildings shall be reasonable.
However, the application of the regulation depends on the nature of the workplace, i.e. a bakery, a cold store, an office, a warehouse.
The associated ACOP goes on to explain:
The temperature in workrooms should provide reasonable comfort without the need for special clothing. Where such a temperature is impractical because of hot or cold processes, all reasonable steps should be taken to achieve a temperature which is as close as possible to comfortable. 'Workroom' means a room where people normally work for more than short periods.
The temperature in workrooms should normally be at least 16 degrees Celsius unless much of the work involves severe physical effort in which case the temperature should be at least 13 degrees Celsius. These temperatures may not, however, ensure reasonable comfort, depending on other factors such as air movement and relative humidity.
HSE have produced a publication called Thermal Comfort in the Workplace HSG194, ISBN 0717624684, £3.50, which provides further guidance.
Although there is no maximum temperature stated in the regulations, the guidance states:
'An acceptable zone of thermal comfort for most people in the UK lies roughly between 13°C (56°F) and 30°C (86°F), with acceptable temperatures for more strenuous work activities concentrated towards the bottom end of the range, and more sedentary activities towards the higher end.
Because the maximum temperature is not stated in the regulation itself, the status of the ACOP must be explained and some cases may require advice or interpretation.
You may need to discuss measures such as, shading of windows, insulation of pipes, providing air cooling plant etc.
Questions may be raised regarding humidity, information on which can be taken from HSG132, Sick Building Syndrome.
In addition, questions may also raised regarding air conditioning, air movement, use of fans and what the employers duty is here. This question would also therefore move onto regulation 6, Ventilation.
The question may also cover some aspects of the Personal Protective Equipment at Work Regulations 1992, especially for those working in warehouses or cold stores.
Wimps, the lot of ya. :p
Try living in south florida during the summertime. Top that off with having the job of pouring concrete house foundations in that heat.... I had a great tan though.
Typically british we moan when its hot and moan when its cold........... :tumble:
Heat is situational. I wouldn't be moaning if I was lying on a beach wearing a bikini with a JD and coke in my hand............................in fact bring it on............ :respekt:
Sorry I don't know you and don't take this the wrong way but I seriously hope you are a female.
:innocent: :run:
I don't see your problem. Im stuck in a room with 3 Air con fans pumping out freezing cold air 24/7 because the machines are more important than the work staff. If im hot in here then i HAVE to turn the cold air on, if i'm freezing then tuff.
Moan moan moan!!! :respekt:
