044 pumps and check valves position
hodge
Hi guys
When I did my Bosch 044 pump setup I fitted a -8AN check valve directly into the top of the pump. Would it make any difference if this valve was mounted outside the tank. I'll keep it as close to the hanger as pos of course.
What's your opinions on this.
Guys in the states are correct, its only worth having the check valves on the pump if running more than one 044. That way if one pump dies you still keep the pressure from the other pump.
They are a fair sized restriction tho.
If it was on my car i wouldn't run the check valves and just feed the fuel pressure into the Syvecs. That way if the pressure drops below a certain threshold based on RPM it will put the car in Limp mode and flag a warning.
Also im not the biggest fan of keeping too much pressure in the rail these days when the engine is off as alot of aftermarket injectors leak slighty as the pinicle seats wear.
Ryan
Ryan
Ryan can you take a fuel pressure feed from my Defi fuel pressure gauge to run to the Syvecs. If so I'll attach the according wires and run them down to the footwell.
Have you noticed any starting/pressure issues Wez. It's going to make the in-tank setup much easier if I don't have a check valve.
Certainly on mine it primes before I start, if you flick the ignition to on you can hear the pump prime, when it stops I turn it over and it starts like normal, same with a Walbro and stock pump :search:
So would you recommend having 1 present chris, and also do you see any issues having it outside the tank.
Only possible hot start issues if the fuel rail vapourises, but it seems people have no real issues without one. I have always run the stock 044 valve when uisng those pumps. I can see no reason not to have it external to the tank.
