Black_Supra Posted January 25, 2011 Share Posted January 25, 2011 Hey guys, yes i searched but my answer is yet not answered. I want to instll my Defi controller and it got 4 wires. Red, Orange, Black - OK But whats with the White wire ? - White: +ILM (To 12 V wire when small light is on) They mean the light when i open the doors ? I got a 94 Jspec MKIV ... the most of you installed the controller at the clock but i got no clock pretty shitty Quote Link to comment Share on other sites More sharing options...
Pudsey Posted January 25, 2011 Share Posted January 25, 2011 Hey guys, yes i searched but my answer is yet not answered. I want to instll my Defi controller and it got 4 wires. Red, Orange, Black - OK But whats with the White wire ? - White: +ILM (To 12 V wire when small light is on) They mean the light when i open the doors ? I got a 94 Jspec MKIV ... the most of you installed the controller at the clock but i got no clock pretty $#@!ty You want to wire this into the dimmer switch for the dash lights, you will have to test the side of the wire you need '+' feed when side lights on. Then when you put your lights on then at night the gauges will draw the feed from when the side light switch/ headlight switch is activated, illuminating your gauges. Job done. NB: I assume by small lamp they really mean side lights on, first stage of the headlight switch. Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted January 26, 2011 Share Posted January 26, 2011 You want to wire this into the dimmer switch for the dash lights, you will have to test the side of the wire you need '+' feed when side lights on. Why do you wire it to the dimmer and not just a live wire that is positive with the lights? I only ask because I have a load of defi gauges installed and they are wired to the dimmer, the problem I have is I have to dim my dashboard lights before the gauges dim. This works but i'd rather have the gauges dim as soon as the lights are on since theyre bright anyway. I'm going to remove most of the gauges but if theres a better place to wire the light sensor too I wouldnt mind switching it over. Quote Link to comment Share on other sites More sharing options...
Black_Supra Posted January 26, 2011 Author Share Posted January 26, 2011 The 94 Spec got no clock, right ? Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted January 26, 2011 Share Posted January 26, 2011 I might be wrong but I think it should have a clock. It should be to the right side of the air vent (left hand side vent) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 26, 2011 Share Posted January 26, 2011 Just wire it into the fag lighter light, that dims according to the dimmer position Quote Link to comment Share on other sites More sharing options...
Black_Supra Posted January 26, 2011 Author Share Posted January 26, 2011 got it installed on the clock, everything works, thanks guys! Quote Link to comment Share on other sites More sharing options...
