Stewart10 Posted January 22, 2011 Share Posted January 22, 2011 A while back I bought some Boot Rubbers from Whifbitz thinking this would put an end to the annoying rattle in the back. However I cannot for the life of me get the old screws out, particularly the bottom ones, they are solidly screwed in. A friend said that forcing them out (by whacking them out) could change the rear shape and not worth risking. Has anyone else had this problem? And are these boot rubbers actually going to stop the rattling anyway or is it really the long strips of rubber that are more effective? Quote Link to comment Share on other sites More sharing options...
Konrad Posted January 22, 2011 Share Posted January 22, 2011 Impact Screwdriver? Oh and yeah, it will stop rattling, done it twice already Quote Link to comment Share on other sites More sharing options...
Homer Posted January 22, 2011 Share Posted January 22, 2011 Very common problem on the older models, the bolt was changed on the laters ones (worth buying from Toyota when you replace the rubbers) What worked for me was using a small hacksaw blade to *carefully* cut a slot in the head of the bolt so you can get a large flathead screw driver in which can apply a great deal more force than a philips allows. Others have tried head on the bolt but obviously you need to be very careful when doing this! Impact drivers also work, but I never tried it Replacing the lower rubbers will solve the boot rattle problem, no doubt about that Another quick fix is to remove the uper ones and add a washer between the rubber and bolt, this forces the lid back down on the lower rubber but it'll only last a year or so, depending on how poor the lower rubbers are. Quote Link to comment Share on other sites More sharing options...
Stewart10 Posted January 22, 2011 Author Share Posted January 22, 2011 Yeah I think the impact screwdriver was the one that was feared would dent the bodywork, I can't be sure though. Good to know that what I've got will sort it though, thank you!! Quote Link to comment Share on other sites More sharing options...
Stevo Posted January 23, 2011 Share Posted January 23, 2011 Will definitely stop the 'shopping trolley' like rattle. Done mine late last year and after applying heat with a small butane gas torch but still rounding off the screw heads, I ended up taking about 3hrs to get them out with a set of mole grips on the head. Just make sure you don't apply too much force and end up snapping the head off the screw otherwise you'll be looking at drilling them out... Quote Link to comment Share on other sites More sharing options...
