Supra rear suspension items - part check also
TonytotheB
Hi chaps
Just took my fairly high mileage Supra into a local mechanic and took a look at the rear parts with the wheels off
Forgive me if these aren't the correct names but I have had a go at matching up descriptions he gave to Paul W's site
If you could help me by providing links to sites where I can purchases these or correct my links, I'd appreciate it
Recommended
Rear /L Tein SS Coilover Top Mount Are these right?
Rear R/L Top strut radius arm bushes and ball joints Is this the upper arm? What about bushes? Are these the bushes
Rear R/L Drop links Here maybe?
Right /R Lower trailing arm, bush and ball joints These?
What exactly are these bushes for? Will they replace all?
Will these cover me for all bushes?
Am I best sending this to Paul for a quote?
Having just wrote this I feel sad that I know very little and am relying on others with knowledge of their car to help :(
Guest wantthatone
drop links are cheap enough mate, ebay or motor factors
rear upper arms, pm keron
rear lower arm, again pm keron
coil over top mounts???? im stuck now
Guest wantthatone
dont panic, these parts are available as second hand items, or if your flush, toyota can supply the upper arms & lower arms at a hefty cost, but do gice keron a try first tony.....
F/R L/R Description Link Price
R L Tein Super Street Top Mount + bearings http://www.camskill.co.uk/products.php?plid=m14b0s1752p12989 183.61
R/L Top strurt radius arm bushes http://www.larkspeed.com/index.pl?p=2413PFSUPRK&a=i 151.9
R/L Ball joints
R L/R Drop Links http://whifbitzperformancetuning.co.uk/toyota-supra-suspension-suspension-arms-track-rods-toyota-p-1551.html 93.08
R R Lower trailing arm http://whifbitzperformancetuning.co.uk/toyota-supra-suspension-suspension-arms-track-rods-toyota-p-1548.html 227.64
R R Lower trailing arm bushes ABOVE
R R Lower trailing arm ball joints
Guest wantthatone
tony i replaced the front & rear drop links on mine for £90, second hand rear lower arms as discussed. re bush what you have with poly bushes mate. then spend the money you saved on something you want....
Guest wantthatone
no problem. i replaced all the bushes on mine with the MVP treet race poly kit, new HSD coilovers, the car now is superb! best ££££ i ever spent mate
