ray007 Posted January 21, 2011 Share Posted January 21, 2011 Hi all Just wondering what peoples opinions are of this manifold in terms of reliability/quality http://wap.ebay.co.uk/Member/F/ViewItem.aspx?aid=320163995205&emvcc=0 Thanks in advance Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 21, 2011 Share Posted January 21, 2011 From what I read, the cheap 'Log' manifolds are much better put together than the cheap tubular types. Probably still in need of a good clean, and much better suited to small, fast spooling setups. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 22, 2011 Share Posted January 22, 2011 Are you looking at putting a kit together yourself? What turbo would you be using and what are your power goals? Contact Wez he knows a thing or 2 about cast manifolds and how some of the different ones on the market compare. The PHR Street Kit uses a cast manifold, if you're piecing a kit together it may be worth contacting them to see if they can supply their manifold separately. Also have a read of THIS THREAD for more info. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 22, 2011 Share Posted January 22, 2011 Are you looking at putting a kit together yourself? What turbo would you be using and what are your power goals? Contact Wez he knows a thing or 2 about cast manifolds and how some of the different ones on the market compare. The PHR Street Kit uses a cast manifold, if you're piecing a kit together it may be worth contacting them to see if they can supply their manifold separately. Also have a read of THIS THREAD for more info. Thanks for the link Nic I was thinking of going for a cast manifold, but they sound awful! Quote Link to comment Share on other sites More sharing options...
Wez Posted January 22, 2011 Share Posted January 22, 2011 If going cast the one to get is an Arnout unit, they are rare but have larger internal area along with larger wastegate port My setup is an Induction Motorsport kit with a PHR 60-1 street turbo, Induction Motorsport modified the wastegate port to make it larger. EDIT: just to add, the SPA unit looks OK but have never seen one in the flesh. Quote Link to comment Share on other sites More sharing options...
dandan Posted January 23, 2011 Share Posted January 23, 2011 Thanks for the link Nic I was thinking of going for a cast manifold, but they sound awful! Mine doesn't. Quote Link to comment Share on other sites More sharing options...
