dcarrter21 Posted January 20, 2011 Share Posted January 20, 2011 Right, here goes. my car as standard had the 5speed torsen diff... i recently brought a v160 gearbox and a 96 tt manual propshaft i fitted the gearbox and then tried to fit the prop but when i did this the doughnut was the wrong pcd.... i looked into this and brought a companion flange from a facelift na 6speed this corrected the doughnut problem and the pcds of the holes matched.. tonight i fitted this new flange, offered up the prop but when i went to bolt up the centre bearing the holes didnt line up! i remember reading somewhere that jamie p has fitted and blown up an n/a diff on his black car, im wondering if im missing a part or something?????? im lost with it now! Dave Link to comment Share on other sites More sharing options...
dude Posted January 20, 2011 Share Posted January 20, 2011 B diffs and A diffs have diff size rear props, the B diff is shorter. strangely an A type prop fits a 6spd and B type diff but the centre bearing doesn't bolt up !!!!!!! Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 20, 2011 Author Share Posted January 20, 2011 soooo, what do you think i need to do to solve this? get a vin number from a tt with a open diff and order the companion flange fron that car?? Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 20, 2011 Author Share Posted January 20, 2011 my props got PA91 on it, is this a part reference or something? Link to comment Share on other sites More sharing options...
Stephen G Posted January 20, 2011 Share Posted January 20, 2011 if you use the rear half of the prop that was in your car would that not work? Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 20, 2011 Author Share Posted January 20, 2011 i only have one propshaft now.... the non turbo prop is very differnt to the turbo one anyway Link to comment Share on other sites More sharing options...
Stephen G Posted January 20, 2011 Share Posted January 20, 2011 My bad, didnt know that. I thought you could change the rear part the same as when you put a 6 speed in to a auto tt but keeping the auto diff Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 20, 2011 Author Share Posted January 20, 2011 i think that the front part of the tt auto prop is shorter than the manual tt prop. but thats just the section that bolts to the gearbox. my problem seems to be at the other end Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 21, 2011 Author Share Posted January 21, 2011 Morning bump, any ideas people?? Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 21, 2011 Author Share Posted January 21, 2011 The flange part number i brought from toyota is 41204-30040 Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 21, 2011 Share Posted January 21, 2011 RECO PROP will alter your existing propshaft to fit, given accurate measurements. I won't use anyone else, very good indeed. http://www.reco-prop.com/ Link to comment Share on other sites More sharing options...
dude Posted January 21, 2011 Share Posted January 21, 2011 All you need is a facelift 6 spd prop. or an auto J spec prop and make a new mount for the centre bearing, job done. Link to comment Share on other sites More sharing options...
