Scott Posted January 20, 2011 Share Posted January 20, 2011 As above really. I'm thinking about a new radiator and I was wondering, as the Auto TT fatty's are all that are stocked now, if the gearbox oil cooler on the radiator would be decent enough as an engine oil cooler? Through reading various opinions it would appear that if not tracking the car I shouldn't really need an oil cooler. If I was on a track with it, it would only be for a bit of fun so I wouldn't be pedal to the metal. In this instance, would it be up to the job? Cheers Link to comment Share on other sites More sharing options...
Matt H Posted January 20, 2011 Share Posted January 20, 2011 I don't know why you would consider this when Oil Coolers are not expensive to start with and are obviously more than up for the job? Link to comment Share on other sites More sharing options...
Scott Posted January 20, 2011 Author Share Posted January 20, 2011 I don't know why you would consider this when Oil Coolers are not expensive to start with and are obviously more than up for the job? 2 birds, 1 stone and loads less hassle. If I'm getting a new radiator anyway I might as well use it to its potential. Link to comment Share on other sites More sharing options...
TrickTT Posted January 20, 2011 Share Posted January 20, 2011 I doubt the flow rate through the autobox gear oil cooler would be sufficient to use it as an engine oil cooler. The pipes are only about 10mm diameter. Link to comment Share on other sites More sharing options...
Scott Posted January 20, 2011 Author Share Posted January 20, 2011 I doubt the flow rate through the autobox gear oil cooler would be sufficient to use it as an engine oil cooler. The pipes are only about 10mm diameter. Ahh, I thought that is what AN10 was. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 20, 2011 Share Posted January 20, 2011 Have a look here, it will give you the comparison sizes. http://en.wikipedia.org/wiki/AN_thread Link to comment Share on other sites More sharing options...
Scott Posted January 20, 2011 Author Share Posted January 20, 2011 Have a look here, it will give you the comparison sizes. http://en.wikipedia.org/wiki/AN_thread Hmm, fair bit bigger then. The thing is, I was thinking about not running a cooler at all. It's really just an afterthought as I am thinking about a new rad. What I don't want is to cause a restriction in the oil system. I presume that is exactly what the auto cooler would do? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 20, 2011 Share Posted January 20, 2011 Better no cooler than a restrictive one. Link to comment Share on other sites More sharing options...
Scott Posted January 20, 2011 Author Share Posted January 20, 2011 Yup, that's that out then Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 20, 2011 Share Posted January 20, 2011 Yup, that's that out then Most definitely not possible but they make a great PAS cooler. Link to comment Share on other sites More sharing options...
Scott Posted January 20, 2011 Author Share Posted January 20, 2011 Most definitely not possible but they make a great PAS cooler. Good shout, I take it that would be a track only necessity though? Nice to have for the odd spirited drive or overkill? Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 20, 2011 Share Posted January 20, 2011 Somewhere like Llandow or a drift circuit can easily overheat or even boil the PAS fluid, so ideal for that sort of thing. Possible overkill on the road, but a "nice" upgrade if you have the time and inclination I suppose. The coolant temp will keep sensible heat in the fluid, and still keep it from getting mad hot Link to comment Share on other sites More sharing options...
Scott Posted January 20, 2011 Author Share Posted January 20, 2011 Somewhere like Llandow or a drift circuit can easily overheat or even boil the PAS fluid, so ideal for that sort of thing. Possible overkill on the road, but a "nice" upgrade if you have the time and inclination I suppose. The coolant temp will keep sensible heat in the fluid, and still keep it from getting mad hot Might go for that. Should be a simple enough DIY job. Cheers Link to comment Share on other sites More sharing options...
