Andrew K Posted January 19, 2011 Share Posted January 19, 2011 Wondering if anybody can help me with this!? Is there any difference between a 5 speed N/A and a 6 speed N/A Flywheel? Quote Link to comment Share on other sites More sharing options...
RobD Posted January 19, 2011 Share Posted January 19, 2011 Yes! Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 19, 2011 Author Share Posted January 19, 2011 Yes! Don't suppose you know what the differences are do you!? Quote Link to comment Share on other sites More sharing options...
neo2810 Posted January 19, 2011 Share Posted January 19, 2011 Different gearbox? Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 19, 2011 Author Share Posted January 19, 2011 Different gearbox? I know the gearbox is different!!!! I want to know what the exact difference is in the two flywheels? Quote Link to comment Share on other sites More sharing options...
neo2810 Posted January 19, 2011 Share Posted January 19, 2011 Ok,ok.... Must be a humour free night... 6 Speed Manual Transmission Specifications (2JZ-GE) Gearbox Model V160 (5/96 - 8/97) V161 (9/97 -07/02) First 3.827 3.724 Second 2.360 2.246 Third 1.685 1.541 Fourth 1.312 1.205 Fifth 1.000 1.000 Sixth 0.793 0.818 Reverse 3.280 3.192 Lubricant Capacity - Gearbox 1.8 Litres - Oil specifications Toyota V160 Gear oil or Castrol Transmax Z Final Drive Ratio 3.769 3.769 Differential Code A02B (5/96 - 7/02) A02B (5/96 - 7/02) Drive Pinion - Number of teeth 13 - Ring Gear - Number of teeth 49 - Ring Gear size 200mm - Driveshaft Diameter 29.15mm - Lubricant Capacity - Differential 1.35 Litres - Oil specifications Standard Non-LSD API GL5 Gear Lube 5 Speed Manual Transmission Specifications (2JZ-GE) Gearbox Model W58 First 3.285 Second 1.894 Third 1.275 Fourth 1.000 Fifth 0.783 Reverse 3.768 Lubricant Capacity - Gearbox 2.6 Litres Oil specifications API GL4 or GL5 75W90 Final Drive 4.083 Differential Code A01A (Non LSD) A01B (Torsen LSD)* Drive Pinion - Number of teeth 11 Ring Gear - Number of teeth 47 Ring Gear size 200mm Driveshaft Diameter 26.50mm (A01A). 29.15mm (A01B) Lubricant Capacity - Differential 1.35 Litres Oil specifications Standard Non-LSD API GL5 Gear Lube *Torsen LSD optional equipment. Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 19, 2011 Share Posted January 19, 2011 I know the gearbox is different!!!! I want to know what the exact difference is in the two flywheels? .....just in case it is relevant the 6 speed na flywheel is slightly different from the 6 speed tt one too........... Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 19, 2011 Author Share Posted January 19, 2011 Thanks guys that helps me out Does anybody know the part number for the 6 speed N/A flywheel ? Quote Link to comment Share on other sites More sharing options...
dude Posted January 19, 2011 Share Posted January 19, 2011 What gearbox do you have ????? Quote Link to comment Share on other sites More sharing options...
HadeS Posted January 19, 2011 Share Posted January 19, 2011 I know the gearbox is different!!!! I want to know what the exact difference is in the two flywheels? V160 or V161 can tak as much power as you want. W58 is different story. Its limited to about 400bhp. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 20, 2011 Author Share Posted January 20, 2011 What gearbox do you have ????? I'm not 100% sure!! I bought it over a year ago from a trader on here, but at the time I didn't know there was two types of 6 speed box!! So never asked. If it's any help, when I bought it all I was told it was all the original parts from the one car and it had the early type small case 6 speed diff. Can you tell from that which box I might have then!? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 20, 2011 Share Posted January 20, 2011 IIRC it's stamped on the casing. It's far more likely to be a V160, V161s are much rarer. Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 20, 2011 Share Posted January 20, 2011 (edited) 160 & 161 have different cooling fin patterns on the case. Iirc there are no stamps on the case From SF, V160: V161: Edited January 20, 2011 by jevansio (see edit history) Quote Link to comment Share on other sites More sharing options...
Batmax Posted January 20, 2011 Share Posted January 20, 2011 I'm not 100% sure!! I bought it over a year ago from a trader on here, but at the time I didn't know there was two types of 6 speed box!! So never asked. If it's any help, when I bought it all I was told it was all the original parts from the one car and it had the early type small case 6 speed diff. Can you tell from that which box I might have then!? You should have an V161 what year is your baby ? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 20, 2011 Share Posted January 20, 2011 It should show what gearbox is in it on the VIN plate Quote Link to comment Share on other sites More sharing options...
EMPEROR Posted January 20, 2011 Share Posted January 20, 2011 .....just in case it is relevant the 6 speed na flywheel is slightly different from the 6 speed tt one too........... Are you sure Scott? Because I've put new TT clutch on the old NA flywheel... And looking at the parts catalog, they have same numbers. The clutches are different, but the flywheel is the same I think... Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 20, 2011 Author Share Posted January 20, 2011 160 & 161 have different cooling fin patterns on the case. Iirc there are no stamps on the case From SF, V160: http://i113.photobucket.com/albums/n204/ezzejacobs/DSC02351.jpg V161: http://img.photobucket.com/albums/v43/cprx7/IMG_0991.jpg Thanks this is great help going by the pictures I deffinatly have the V161 gearbox! Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 20, 2011 Author Share Posted January 20, 2011 So now does anybody know the part number for a 6 speed N/A flywheel, that suits a V161 gearbox!? Or has somebody out there got one they are willing to sell ? Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 20, 2011 Share Posted January 20, 2011 Are you sure Scott? Because I've put new TT clutch on the old NA flywheel... And looking at the parts catalog, they have same numbers. The clutches are different, but the flywheel is the same I think... ah I think you may be right, knew something was different! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 20, 2011 Share Posted January 20, 2011 If it's the same as the TT flywheel I have a good used one, low miles. I have a good used TT clutch and new ones in stock, but I would guess the clutches differ? Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 20, 2011 Author Share Posted January 20, 2011 Thanks Chris but I've got the TT flywheel still that came with the parts when I bought them! Im a bit fussy and want to do the job properly! It's just that I'm unsure if there's two different types between the TT and N/A flywheels!? as its the N/A 6 speed flywheel that I'm after!! Are both part numbers the same for both then? Quote Link to comment Share on other sites More sharing options...
EMPEROR Posted January 20, 2011 Share Posted January 20, 2011 /offtopic Chris, I think you are kinda running out of space................ on the desktop LOL Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 20, 2011 Author Share Posted January 20, 2011 Anyone?? Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 22, 2011 Author Share Posted January 22, 2011 If it's the same as the TT flywheel I have a good used one, low miles. I have a good used TT clutch and new ones in stock, but I would guess the clutches differ? Is this the part number for the 6 speed N/A flywheel !? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 22, 2011 Share Posted January 22, 2011 Yes, the earlier screen shot was for the late 6 speed N/A. Here is the part number search for the TT 6 speed flywheel, same number: Quote Link to comment Share on other sites More sharing options...
