w41k3r Posted January 19, 2011 Share Posted January 19, 2011 I bought a 2nd hand e manage package of ebay that had everything ready to fit only thing is it came out of a mr2, now the question is before i buy a universal harness for it is there any way of telling if the one i have is universal or if its mr2 specific ?? not sure if it would help but i could take a pic if needed Quote Link to comment Share on other sites More sharing options...
Nic Posted January 19, 2011 Share Posted January 19, 2011 Can you post a pic of the harness, should be able to tell if it is an MR2 specific one or universal. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 19, 2011 Share Posted January 19, 2011 It should already have a universal cable, as thats how they come, the only car specific part it could have is an ECU fields harness that enables it to be connected to this rather than straight to the ECU harness, so you will be able to remove it from the fields harness and graft into you ECU harness. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 19, 2011 Share Posted January 19, 2011 The MR2 specific harness as you say will have a bridging harness with plugs on it to fit between the ECU and wiring loom, the other end will plug into the Emanage. The universal harness will just have the plugs for the Emanage, the other end open so it can be spliced onto the loom. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 19, 2011 Share Posted January 19, 2011 I thought that was what i said. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 19, 2011 Author Share Posted January 19, 2011 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 19, 2011 Share Posted January 19, 2011 Yep thats just the universal harness that they come with, so providing you have a wiring diagram for both the ECU and the emanage you should be fine. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 19, 2011 Share Posted January 19, 2011 Universal harness. edit: too slow, yes what he said Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 19, 2011 Author Share Posted January 19, 2011 cheers for the help both of you, one, well two more things, is the mr2 going to use similar wires to the supra and is that the only harness i need? (off to find wiring diagram) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 19, 2011 Share Posted January 19, 2011 Yes there are the two plugs there, you will have all the connection's you will need there, its just that different engines will use different wires, differences in things like whether the car has MFA or MAP sensors etc, but essentially the same types of connection's. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 20, 2011 Author Share Posted January 20, 2011 thanks Tricky-Ricky big help im sure ill have fun with this lot of wires lol Quote Link to comment Share on other sites More sharing options...
