Alex Posted January 4, 2003 Share Posted January 4, 2003 What's the exact size of the j-spec brakes please? The discs that is. They are 280mm in dia - I need the thickness of the disc and the size of the "hub" bit inc the diameter of the centre hole. Does anyone know if you can use a bigger disc in the same calipers? Many Thanks I'll be able to explain why when I've got the answers.... Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted January 4, 2003 Share Posted January 4, 2003 I can tell you that the hub center is 60mm, I don't think you can use a larger disc with the same caliper unless you get some adapters made up. Link to comment Share on other sites More sharing options...
Druid Posted January 4, 2003 Share Posted January 4, 2003 I'd be surprised if larger discs fit in combination with the same calipers. Link to comment Share on other sites More sharing options...
Alex Posted January 5, 2003 Author Share Posted January 5, 2003 I'd assumed that I would need to re-position the caliper for a bigger disc. I was just checking. Thanks Ibrar, thanks for the first measurement. NEXT! Link to comment Share on other sites More sharing options...
