Removing brake level indicator wire
hodge
Its only a switch, so either open switch or closed switch. If the light comes on then just link the wires together, if it doesn't just leave them apart.
Personally I would rather leave it there though. I like to know if my brakes are leaking and the fluid is low :)
When it comes to safety, no matter how minimal you want to go, you should stop at the removal of system failure warning lights. If you got an instant line failure on the road the first thing you would know about it would be when the brakes failed, if this lead to you causing a fatal accident how would you live with yourself? Removing a warning feature for the sake of a look, is just plain stupid and totally irresponsible. I wondered how far people might go with the minimal look, this is madness.
