steaming up!
Guest wantthatone
Guest wantthatone
hi guys, can anyone confirm if i need to replace the boot rubber seal, the car seems to steam up at present. theres no water in boot well or anywhere i can see. just find it annoying:( after say 5 mins it starts to mist up.....
Guest wantthatone
cheers peeps, just on another note. im not sure when the air con was last run or serviced any advice on this please, should i switch it on once a week or get it gassed & serviced...
It doesn't need servicing as such. If it works, great, if it doesn't it's got a leak and needs refilling. The usual advice is to use it once in a while to keep it working properly. A lot of aircon systems seem to develop a slow leak if unused, probably around the seals.
Guest wantthatone
well the misting up is now sorted.... however, after some realy severe frost i have noticed condensation on the inside of the rear window which freezes, as it dries the water drips on to the luggage blind etc... any ideas? i have checked the tail gate rubber, all seems ok, i have new boot rubbers to fit, the ones that fit the boot & fit the bodywork. i will try this & see if any remedy has been achieved! but any ideas guys welcome, as we are doing a full stereo install soon & carbon interior fit... i need it water tight peeps...
Check:-
1.Boot seal by doing chalk test
2.Spoiler bolts as the water can run through the holes
3.Electric aerial drain and body on the right hand side of the boot.
4. Worse case scenario glass seal.
The best way I have found on other cars is to strip the boot of all trim and lie in the boot with the tailgate closed and get someone to hose down the back of the car. With no trim you can soon see where the water is coming from.
