Scott M's Supra Build Thread
Scott
  • Replies 787
cool mate, you decided the non-dbb after seeing my results then? Yours should make more since its the billet wheel, what .ar you using?
Yours, Ricky's and a few others I have seen making the numbers I am after. I just can't justify the extra outlay when it spools the way it does and hits the figures I am after.
0.81. I'm not going to let it make more though. It'll be getting capped at 700..... for now :innocent:
Ryan will map it as high as poss, then you can just turn it down. :D
Na, I'm capping it at 700 to save the engine..... not me lol. Whatever boost makes around that figure is what the max will be. I'm thinking about building a spare engine though :innocent:
I'll be a happy man if I never have to remove a set of stock tubbys again. I don't know how the traders can be bothered with that job, it's a royal PITA. Anyway 3 hours later and the job is done....
Thankfully my hands seem to have survived the carnage. Time to chill with the family :)
Oh just remembered. Before I took the turbos off I did a compression test.....
1 - 147
2 - 143
3 - 145
4 - 147
5 - 145
6 - 143
Quite happy with that. It's amazing how much you fear the worst before doing a test like that. I'll need to try and remember to do the test again once the new head is on :)
Day no.3
Only had a couple of hours to work on it today but I got a fair bit done. A couple of the harder jobs anyway.
Timing belt, pulley wheel, idlers, water pump, throttle body etc etc all removed.
Got my first injury too. Amazingly it happened on the power steering pulley rather than while removing the turbos lol. How I managed it I'll never know. The funny part was how my wedding ring took the skin off like kebab meat being cut on a skewer :D
Not got a great deal to strip off now. Going MUCH faster and easier than I thought it would. I can't believe how easily the pulley wheel came off :p
Going to be a nice build this one. I like stealthy looking engine bays. good stuff Scott
Cheers mate :)
coming along nice mate, you got a time scale your shooting for?? if you need a look at mine if you get stuck gimi a shout, and i'll pop over.
No time scale bud, if I have it on the road for the summer I'll be happy. Cheers mate, might just do that. I'll no doubt see it if there are any meets organised, where I'll turn up in the derv :D
Pull the thing!!
Nothing to pull it with or put it onto unfortunately :(
Updated Spec/Shopping List
On the car:
Greddy 4 Row Intercooler & Hard Pipe Kit
HKS SSQV 2 BOV
Innovate AFR Gauge
Glowshift EGT Gauge
Glowshift Boost Gauge
New Oil Pump
New Water Pump
Front Crank Seal
Ready to Go On:
ASI Radiator
Boostlogic Manifold
Boostlogic Downpipe
Boostlogic Midpipe
Oil Feed & Return
AEM Filter Kit
GSC Stage 1 Cams
900cc Bosch Injectors
FIC Twin Feed Fuel Rail
Tial Wastegate
OEM Gasket Kit
OEM Crank Pulley Bolt
OEM Timing Belt
OEM Aux Belt
Brian Crower Stainless Springs & Retainers
Short Shift Kit
Bosch Fuel Pump & SRD Fitting Kit
19 Row Oil Cooler Kit with Mocal Thermostatic Sandwich Plate
ARP Head Stud Kit
Billet Timing Belt Tensioner Bracket
Precision 6765 Billet Turbo with Ported H Cover (HPS)
Titan (ATI) Crank Pulley Wheel
Aeromotive FPR & Fittings
Adjustable Vernier Cam Pulleys
Universal Oil Sandwich Plate with 4 1/8" NPT Take Offs
SPA Oil Pressure/Temperature Gauge
To Buy:
OEM Manifold Studs for Turbo
OEM Manifold Nuts
OEM Downpipe Nuts for Turbo
OEM Thermostat
OEM Sump Bolt & Washer
Solid Selector Bushes
Boostlogic 4" Exhaust
Clutch (RPS Carbon/Carbon is the preference at the moment)
Syvecs S6 ECU & Loom Adapter
Oil Pressure Sensor x2
Oil Temperature Sensor x2
Syvecs Wideband Lambda Sensor (For ECU)
Knock Sensor for Syvecs
Boost Solenoid for Syvecs
Switches & Wiring for TC & Boost
Getting there slowly but surely. The list constantly evolves as I think of things I need to do :)
Total spend so far is £8k. Approx 5k to go if the list stays as it is (I'm thinking of a cheaper clutch).
