clay Posted April 3, 2013 Share Posted April 3, 2013 Hello mate if you pm me your address. I can send you a m10x 1mm pitch set screw its 25mm long or if any one nose the right size. I mite have that aswell. if its coming up as a weard size it may be UNF. Quote Link to comment Share on other sites More sharing options...
Scott Posted April 3, 2013 Author Share Posted April 3, 2013 can you not drill and tap a new thread ? to what ever bolt you have that almost fits, must admit i was shocked with the little nigly bits of a single build, fabricating a mid or down pipe is a pain sometimes I could but I don't want to go down this route at the moment. I would be worried about swarf in the radiator and I believe the bolt either has to be alloy or plastic to stop it reacting with the alloy. Hello mate if you pm me your address. I can send you a m10x 1mm pitch set screw its 25mm long or if any one nose the right size. I mite have that aswell. if its coming up as a weard size it may be UNF. I ordered one up last week, should be here today/tomorrow going by the despatch notification. If it's no good then I'll need to concentrate on finding out what thread it is, if I get a hit I'll definitely keep you in mind. Thanks for the offer Quote Link to comment Share on other sites More sharing options...
James Posted April 3, 2013 Share Posted April 3, 2013 Scott, I have a machinery handbook that could help with the thread dilemma. Get yer calipers oot and measure the inner minor width and see if you can get the pitch as well with a thread gauge (surely your work would have some?). Quote Link to comment Share on other sites More sharing options...
Scott Posted April 3, 2013 Author Share Posted April 3, 2013 Scott, I have a machinery handbook that could help with the thread dilemma. Get yer calipers oot and measure the inner minor width and see if you can get the pitch as well with a thread gauge (surely your work would have some?). To be honest I couldn't be bothered doing that lol. I've got a set of thread gauges here, somewhere, and I've got about half a dozen zeus books. Now that the finger has been extracted this is the route I will be going down if I don't get anywhere with the M10 bolt. Cheers Quote Link to comment Share on other sites More sharing options...
clay Posted April 4, 2013 Share Posted April 4, 2013 Just thort id ask do you no what rad it is.? And if someone in kent had the same rad. If i can see it i maybe abell to identify the thread. Quote Link to comment Share on other sites More sharing options...
Scott Posted April 4, 2013 Author Share Posted April 4, 2013 It's an ASI radiator. I've ordered a couple of bolts through work, if these don't fit then it's getting tapped out lol. Quote Link to comment Share on other sites More sharing options...
hodge Posted April 4, 2013 Share Posted April 4, 2013 Just have the drain plug welded up Scott. That's why I did. The plug that came with my ASI rad began to leak after a week of use. When I wantvto change my coolant I just take the bottom water pipe off. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 4, 2013 Share Posted April 4, 2013 Just have the drain plug welded up Scott. That's why I did. The plug that came with my ASI rad began to leak after a week of use. When I wantvto change my coolant I just take the bottom water pipe off. I have a feeling mine weeps from the plastic bung too Quote Link to comment Share on other sites More sharing options...
hodge Posted April 4, 2013 Share Posted April 4, 2013 I have a feeling mine weeps from the plastic bung too Alloy welding is your friend. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 4, 2013 Share Posted April 4, 2013 Alloy welding is your friend. No lee is my freind Quote Link to comment Share on other sites More sharing options...
Scott Posted April 4, 2013 Author Share Posted April 4, 2013 Just have the drain plug welded up Scott. That's why I did. The plug that came with my ASI rad began to leak after a week of use. When I wantvto change my coolant I just take the bottom water pipe off. I had that thought in mind too. I need to find an alloy welder to bead an intercooler pipe so might as well kill 2 birds with 1 stone Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 4, 2013 Share Posted November 4, 2013 Any updates on this scott its been a while now, like over 2 years now Quote Link to comment Share on other sites More sharing options...
clay Posted November 4, 2013 Share Posted November 4, 2013 He is to bizy drinking his homebrew. LOL Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 4, 2013 Share Posted November 4, 2013 Someone has got to drag him away from that and watching willy shape fireworks , to get this car done such a shame was such a nice car, but I guess that he has not driven it in so long even if it was finished it wouldnt get used Quote Link to comment Share on other sites More sharing options...
Scott Posted November 4, 2013 Author Share Posted November 4, 2013 Any updates on this scott its been a while now, like over 2 years now It's moved on quite a way from the last update, not really got anything to post up though Quote Link to comment Share on other sites More sharing options...
Big Supes Posted November 4, 2013 Share Posted November 4, 2013 Lovely car, Scott. Some tasteful mods on there. Those Angel Eyes are awesome. Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 4, 2013 Share Posted November 4, 2013 It's moved on quite a way from the last update, not really got anything to post up though I know you was after the oil return so I expect it must be in the closing stages, best of luck with it though mate, make sure you double check things brfore you start as youbmay of missed little bits with the long time gaps Quote Link to comment Share on other sites More sharing options...
Scott Posted April 6, 2014 Author Share Posted April 6, 2014 http://www.mkivsuprastar.com/mkivsuprastar/Pics/SingleInstall/a095c26fb74763e093a31982c9c83ea6.jpg http://www.mkivsuprastar.com/mkivsuprastar/Pics/SingleInstall/81fb3460018b49b7be7b290328f8c38e.jpg Quote Link to comment Share on other sites More sharing options...
James Posted April 6, 2014 Share Posted April 6, 2014 I don't believe my eyes Quote Link to comment Share on other sites More sharing options...
Scott Posted April 6, 2014 Author Share Posted April 6, 2014 I don't believe my eyes Told you It was actually the Wife that shooed me into the garage to get my finger out Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted April 6, 2014 Share Posted April 6, 2014 Quote Link to comment Share on other sites More sharing options...
tony tt Posted April 6, 2014 Share Posted April 6, 2014 If anything it must be the longest build thread to date!! Quote Link to comment Share on other sites More sharing options...
Scott Posted April 6, 2014 Author Share Posted April 6, 2014 If anything it must be the longest build thread to date!! It will be by the time it's done. That's me in hibernation for another 18 months Quote Link to comment Share on other sites More sharing options...
tony tt Posted April 6, 2014 Share Posted April 6, 2014 It will be by the time it's done. That's me in hibernation for another 18 months Hahahaha Quote Link to comment Share on other sites More sharing options...
Scott Posted April 7, 2014 Author Share Posted April 7, 2014 Well the battery still works, hooked it up and nothing went on fire. A good day overall Also sorted out the air valve on the power steering pump. http://www.mkivsuprastar.com/mkivsuprastar/Pics/SingleInstall/fb087bc30b362bb8896620655f0c06ca.jpg Quote Link to comment Share on other sites More sharing options...
