RobD's NA-TT Engine Conversion thread :)
RobD
Thought I'd give you guys a little update! Instead of fitting hybrid twins, I've just put a deposit down on this...
http://www.mkivsupra.net/vbb/showthread.php?237035-PHR-Turbo-Kit
:D
Thanks to Adrian and Tony_TT for the deal and helping me out on this! I owe you two a pint! :D
The hybrids will be up for sale at the end of this month once they get delivered for anyone who's interested :)
:D
:friday::thumbs:
  • 4 weeks later...
Done some more work today, been doing loads of overtime to get mire money to throw at this so sorry it's been a while since the last update!
This was how the block looked this morning...
These pics show the corrosin to the water ways...
And how it's looking now...
Now the blocks got to be sent away to the machine shop to be decked then once it comes back and I have some spare cash I'll be buying the following...
Acl bearings
ARP head stud kit
ARP con rod bolt kit
OEM piston rings
TT Oil Pump
For the single I'll be buying the following...
AEM EMS ( probably V2!)
Siemens 850cc top feed injectors
High flow fuel rail
SARD FPR and Gauge
SuperSpark Coilpacks
Brian Crowler Cams ( unsure what ones yet!)
I'm still deciding what else to buy yet but those are a definite!
Subscribed chap this should be good :D
If you need a hand I'm only down the road mate ;)
J
Thanks bud, appreciate it :)
yum yum, looking good rob
Thanks mate :)
Get the block dipped whilst its bare and clean the shit out of it with hot, soapy water.
I intend to mate, then give it a once over with some high temp paint! :)
Experience tells me you knock out all the core plugs and have a look inside the water jackets before spending money on that block, it's been run for a LOOOOONG time with no corrosion inhibitor in it and the water jackets could be very nasty, giving thin bore walls. If that's the case I'd find another block. Even a converted N/A block is better than something badly internally corroded. Hope it's OK for you, but better to know now than after it's decked and bored.
