What idle speed
ulysees
When warm it should be 650-850rpm
When cold it can be up to 1800rpm, depending on the exterior temp.
Does the car have a standard ECU? Any signal fudgers installed?
Does it ever drop below 1200rpm?
If not then I'd look towards a sticky idle control valve. Easily fixed.
WTF? didnt notice this.. as far as i can see there still there when i do an Edit on them, the .IMG link is still there from Photobucket??
Any Idea's?
I'll report it to Mawbs, I'd assumed they were from photobucket or similar, but just noticed they're forum hosted. We'll try and get them back :)
Edit: Fixed
they are from photobucket dude, do i need to change anything here
Should be fixed now Geo, they were loaded from the forum (as they should be) but there seems to be a problem with the linking, I've corrected it manually but asked Mawby to check out what happened
Ok i took icv off and cleaned it and noticed two of the wires werent pushed all the way in the connector block so i pushed them all the way in and now it idles too low lol.
I set the TPS to the central position, i tried it all the way to the left and all the way to the right but it still idles too low, almost cutting out.
