marc_p Posted January 14, 2011 Share Posted January 14, 2011 I know this will have been asked on here before but when I did a search it just came up with an immense amount of unrelated threads and I couldn't see anything. Anyway, my question is, how could you make a 2JZ powered Supra 4WD, I personally have know intentions of ever wanting to do it, but it was more out of curiosity on how you could do it, I assume it would need a Skyline style setup as that has a longitudinal(sp?) engine, but I don't know how that works either TBH, Would it be possibe to do it on the Getrag box aswell? Quote Link to comment Share on other sites More sharing options...
clapyohandz Posted January 14, 2011 Share Posted January 14, 2011 not quite everything you mentionned but this is the idea, thanks to our Russian friends !* http://www.mkivsupra.net/vbb/showthread.php?237195-Specs-of-this-built-mk4 Quote Link to comment Share on other sites More sharing options...
heckler Posted January 14, 2011 Share Posted January 14, 2011 I know this will have been asked on here before but when I did a search it just came up with an immense amount of unrelated threads and I couldn't see anything. Anyway, my question is, how could you make a 2JZ powered Supra 4WD, I personally have know intentions of ever wanting to do it, but it was more out of curiosity on how you could do it, I assume it would need a Skyline style setup as that has a longitudinal(sp?) engine, but I don't know how that works either TBH, Would it be possibe to do it on the Getrag box aswell? Its been done. ei7a8GBT4Xk Quote Link to comment Share on other sites More sharing options...
marc_p Posted January 14, 2011 Author Share Posted January 14, 2011 not quite everything you mentionned but this is the idea, thanks to our Russian friends !* http://www.mkivsupra.net/vbb/showthread.php?237195-Specs-of-this-built-mk4 Its been done. ei7a8GBT4Xk Cheers for the links guys's but it was more me wondering how you could do it on a 2JZ lump. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 14, 2011 Share Posted January 14, 2011 2jz with custom bell housing mated to r33gtr running gear maybe a good way Quote Link to comment Share on other sites More sharing options...
Scott Posted January 14, 2011 Share Posted January 14, 2011 I was curious how they did it when I saw that car previously. as anyone heard anything about that car? Seemed to all go quiet, as if it didn't work Short prop to transfer box, transfer box to rear diff, transfer box to front diff? Something like this I would imagine. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 14, 2011 Share Posted January 14, 2011 The R34 skyline uses a variation of the Getrag box found in the Supra (apparently) t That may aid a conversion. Quote Link to comment Share on other sites More sharing options...
Stephen G Posted January 14, 2011 Share Posted January 14, 2011 here is a vid of a gtr skyline with a 2jz so you would think it might be possible to put the skyline front drivetrain setup into a supra Quote Link to comment Share on other sites More sharing options...
Lude Posted January 14, 2011 Share Posted January 14, 2011 maybe use the GT4 setup/parts, lots of custom work so it fits the the 2J instead of 3SGTE Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted January 14, 2011 Share Posted January 14, 2011 Some guy on supra forums made his supra 4 wheel drive! I'm sure someone will come up with the link soon! Quote Link to comment Share on other sites More sharing options...
RobD Posted January 14, 2011 Share Posted January 14, 2011 (edited) I was under the impression that the skyline gtr's front part of the transmission enters the engines sump? So I can't see how that would be used! Did they make an aristo 4wd v8 edition? Perhaps use the drivetrain etc from that?! EDIT: they do a v8 aristo using the 1uz, so no doubt you could use the transmission from that! Edited January 14, 2011 by RobD (see edit history) Quote Link to comment Share on other sites More sharing options...
Konrad Posted January 14, 2011 Share Posted January 14, 2011 I can't find it now, but there is Supra in Poland with 4WD from some american car, other than that it is 2JZ single turbo engine. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted January 14, 2011 Share Posted January 14, 2011 Simples stick the 4wd gearbox, drive train and engine in from an aristo. The V8 aristo comes with a 4WD box. Its not a huge power capable box but its 4WD and will drop straight in. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 14, 2011 Share Posted January 14, 2011 As above, 4WD gearbox and sump etc from a V8 Aristo. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted January 15, 2011 Share Posted January 15, 2011 Buy this and swap engine and gearbox and running gear http://www.terra2imports.ca/import-japan120863128586452.htm Quote Link to comment Share on other sites More sharing options...
Guest Edd1Ninety9 Posted January 15, 2011 Share Posted January 15, 2011 So does that mean you'd be restricted to automatic transmission? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted January 15, 2011 Share Posted January 15, 2011 Am I the only one who wouldn't want a 4WD Supra? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 15, 2011 Share Posted January 15, 2011 Am I the only one who wouldn't want a 4WD Supra? I'm the same, well sort of. I would love a 4wd Supra for a purpose (time attack or something like that), but I would always want a standard drivetrain one for general fun use Quote Link to comment Share on other sites More sharing options...
johnny g Posted January 15, 2011 Share Posted January 15, 2011 I'm the same, well sort of. I would love a 4wd Supra for a purpose (time attack or something like that), but I would always want a standard drivetrain one for general fun use Or for the snow Quote Link to comment Share on other sites More sharing options...
Scott Posted January 15, 2011 Share Posted January 15, 2011 Or for the snow Yeah, good shout lol. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted January 16, 2011 Share Posted January 16, 2011 So does that mean you'd be restricted to automatic transmission? Yeesh you boys want everything lol Or for the snow Yeah, good shout lol. Fella's, fella's, fella's you don't need 4wd for snow, my aristo performed as well as any 4wd in the snow because I put proper winter/snow tyres on. Makes the world of difference. Push snow mode button to lock out first gear and kickdown floor it and let the TC do its job!! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 16, 2011 Share Posted January 16, 2011 I wouldn't be a Supra owner if they were 4wd Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 16, 2011 Share Posted January 16, 2011 Am I the only one who wouldn't want a 4WD Supra? Not at all mate. A 4WD supra is heresy! With a well set up chassis they can be just as quick as any 4WD round the track! Quote Link to comment Share on other sites More sharing options...
